side mirrors
side mirrors
broke my side mirrow right off the car... can't remember how i took the oen mirrow covers off (they are now cf.
heres what i need to know 1 how to remove the cf cover
2how to take the mirrow off the car .
3how to remove the offending part that holds the mirrow to the door
thanks in advance steve
the triangular interior piece with mirror controls: pop the bottom snaps out gently, then slide up, there's a downward hook on the top corner. 3 torx screws inside. 2 in plain view, one under the rubber seal under a sticker. the plug, just pull out gently.
will be difficult to remove the CF cover. try fish string and patience. might help to soak it first.
a flat head screw driver wrapped in duct tape helps get the lower part off, (door open).
no idea on the cf covers, i just took a guess they were stuck on with 3m double sided or something. if it snaps on, then it should come off just the same (gently).
good luck
good luck
