HID Fog Lights installed-good but strange glitch
Old Jan 6, 2010 | 08:03 AM
LovemyTT's Avatar
LovemyTT is infamous around these parts
We all want to see some dang pictures of it!
Old Jan 6, 2010 | 09:37 AM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
NOTE: The low headlight beams are set to point really low. For some reason I could only adjust the drivers headlight up and down on the low beam. The passenger side would move very little on the low beam like it was stuck or something. I took it apart and it looked fine and couldn't understand why it wouldn't move much. So in the end I set both low beams at the same height=LOW.
So I installed the fog light HID's to help as I could adjust those equally on both sides no problem. So in the end I have enough light for me to see on the road well. I'll take some more showing the difference with and without the foglights soon.
Old Jan 6, 2010 | 09:44 AM
XLR82XS's Avatar
Originally Posted by Soundeffects
Thanks TURBO ELECTRO...I'm on it this weekend. Until then I'm enjoying the cold weather!
If you enjoy cold weather come to Detroit now.
Old Jan 6, 2010 | 10:18 AM
LamboTT's Avatar
Detroit, lol. I've barely even seen snow before. I wouldn't make it. What do you drive in the snow?
Old Jan 6, 2010 | 06:18 PM
sc_trojan's Avatar
sc_trojan has a spectacular aura aboutsc_trojan has a spectacular aura about
looks like I will try this mod too. amazon has these for $60!
Old Jan 6, 2010 | 10:43 PM
LamboTT's Avatar
If you look at the fog light there is only one wire you connect and its the power. The other ground wire is right next to the opening of the fog light where the bulb goes, just unplug it and plug it into the HID harness side.
I've finally decided that I don't want to take a chance so I'm going to run a relay ASAP until then, no fogs.
Old Jan 6, 2010 | 11:26 PM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Why not just change the bulbs to 8k ones if that is th elook you want?
Old Sep 7, 2010 | 05:08 PM
XLR82XS's Avatar
Volvo XC70. Downpipe and bluetooth
The_Ruski_Driver
Oct 25, 2015 08:40 PM
RallyBird
Oct 7, 2015 01:20 PM
hacellular
Aug 31, 2015 08:34 AM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
