Headers: The truth!!
Old Jan 4, 2010 | 07:46 PM
wross996TT's Avatar
Originally Posted by skandalis447
in k16based turbos there is not significant gain...however as you go with bigger turbos,spool up time is less with headers...
uh..please explain this...do you mean smaller headers or larger headers...the larger ones will increase spool up time.
To the OP, as already mentioned...we have known this for years....LOL, but you still see the ebay header threads now and then, so perhaps good reminder for newbies.
Old Jan 4, 2010 | 08:15 PM
DJM's Avatar
DJM
DJM is just really niceDJM is just really niceDJM is just really niceDJM is just really nice
What about porting stock headers, will doing so get you anything like 100-200 rpm sooner spool up or anything positive for the effort?
Old Jan 4, 2010 | 09:19 PM
unvmy996's Avatar
ported headers again may make that little difference caitently worth it since a port is cheap , but scotty /divex ran 10s with plain oll regular manifolds.
Old Jan 5, 2010 | 08:40 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I had a conversation with a shop a few years ago and they basically said the same thing and stated thats why they never produced any. Now that same shop makes and sells headers for both the 996 and 997.... wonder why?
Old Jan 5, 2010 | 08:59 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
when my car hits 1,3bar with 18g turbos it spools 200-300rpm sooner with fabspeed headers...I did a comparison within one hour...before and after installation...
Old Jan 5, 2010 | 09:40 AM
Josh/AWE's Avatar
Yea, this is something we have been preaching for years. Even on a K24 car they are not needed.
Old Jan 5, 2010 | 09:58 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
unless you run externals....
Old Jan 5, 2010 | 10:19 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Originally Posted by AMS
I hate to stir the pot but I have to let you guys in on something that we've know for a while and even built a set of headers on our 996tt to prove the fact.
Headers on a stock based turbo do nothing!!
Years ago when we were developing Mitsubishi EVO headers we build a really nice large diameter header for a 400whp EVO VIII we had here. They did absolutely nothing, maybe 2 to 3 horsepower but nothing you couldn't attribute to standard dyno variance. The only think it did do was create lag from the large runners.
Now on to the 996tt headers.
We designed a nice set of headers with cast merge collectors and a cast head flange that has a smooth transition from the exhaust port to the tubular runners. After fitting them to the car and doing a direct back to back test (same day) the results were as expected, no real measurable gain. at 650wph each run was 5-10 hp in variance and there was no real measurable difference in the power level from the headers. The headers are larger internal diameter than stock.
The thing with turbo cars is that you can get away with a much more compromised header design than NA cars. As long as your exhaust back-pressure is significant you really won't benefit from a well designed header. In my opinion, until you get away from stock style turbo's and over 750whp it's better to stick with stock headers, otherwise it's just a waste of money. Better spend it on a turbo intake system, intercoolers, tune, etc...
I know this may create some heated debate but it is what it is and I'd rather see owners spend their money on parts that work and make horsepower.
-Martin
Thank a lot for sharing your info! However, I wonder if k24/20g isn't big enough to benefit from changing a set of good designed header? Tks!
Old Jan 5, 2010 | 10:35 AM
heavychevy's Avatar
Because the people on 6speed in this section are a small percentage of the overall owners of Porsche's and that relates to many cars. People come in the door and want headers, they are cheap to re-produce and you can make a lot of money off them. In other words, there are a lot of people that are in fact still clueless, even here on the site, newbs come everyday not knowing.
Good chance the headers are from China an rebranded.
And the headers could be for NA car too.
Old Jan 5, 2010 | 10:46 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Exactly, we do not include them in most packages unless they are using different turbos or power is near 700hp.
They are an option for guys that like to leave nothing on the table, however.
Old Jan 5, 2010 | 02:05 PM
gt2rs's Avatar
gt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of light
So since ill soon have K24/20G on my car and i cant really decide after reading alot on the header subject .... would i benefit anything from a good header on a my GT2 or would it make it worse ?
Please advice gurus :-)
Old Jan 5, 2010 | 02:50 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
-Martin
powiem wiecej, seryjne kolektory bez problemu dzialaja do 700 prawdziwych koni, niesamowite jest to ja ci pozostali tunerzy nabijaja tych biednych ludzi w butelke!
ciesze sie ze bierzecie sie za tuning porscha !!!
pozdr.K
Old Jan 5, 2010 | 03:47 PM
unvmy996's Avatar
Ya ... Whatever you say buddy! Care to translate in English?
Old Jan 5, 2010 | 03:54 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I would only port your stock headers for you K24/20G.
Old Jan 5, 2010 | 04:01 PM
gt2rs's Avatar
Many thanks thats already done :-) .
