Ordering Turbo "S" coupe is thicker steering wheel worth it
Old 12-19-2004, 10:21 PM
teutonictrio's Avatar
Banned for Eternity
teutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond repute
How about just having your stock wheel wrapped in an extra layer of leather? Probably pretty cheap, and the only disadvantage is that the diameter will be more than the factory 'thicker' wheel.
  #32
Old 12-20-2004, 12:21 AM
StephenTi's Avatar
StephenTi is on a distinguished road
Lou... I think you're confusing thickness of the wheel vs. diameter of the wheel.
Thickness is referring to the girth (circumference) of the wheel, as in how thick it feels in your hands.
Diameter is referring to the diameter, as in how part your hands are apart when gripping opposite ends of the steering wheel.
The oem thicker wheel can't be 280mm in diameter... that would be ridiculously small... barely bigger than a typical steering wheel for computers and playstation.
OEM diameter from what KPV had posted is 362mm, and KPV's special order wheel is 320mm. Typical aftermarket wheel for our car is ~340mm in diameter.
So ideally, the oem steering wheel should have a greater circumference and smaller diameter... hope that helps.
COBB Tuning
01-29-2022 09:42 AM
MAcarbon
03-06-2017 08:16 AM
no1joey
09-02-2015 12:32 AM
MAcarbon
08-19-2015 06:22 PM
MAcarbon
08-19-2015 04:52 PM
Quick Reply: Ordering Turbo "S" coupe is thicker steering wheel worth it
