Alu LWFW+Cluth Master 3 Fiber = Trouble.
Old Jan 10, 2010 | 05:42 AM
  #31
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Originally Posted by MARKSKI@911tuning
if you cut the pin on the slave that will change the point... we do that on the ATS....
Sounds like a simple solution to the problem of a high bite point
Old Jan 10, 2010 | 06:09 AM
  #32
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
I have the same high engagement - short engagement range issue. I have a Clutchmasters custom stage 3 which is I was told has the reworked fulcrum for extra clamping force and kevlar/fiber hybrid disk.
I have debated putting in a clutch stop to reduce the pedal travel range (don't want to loose safety feature of no start unless clutch depressed), but otherwise am stumped. I've gotten used to it and it holds fantastic at speed, so I'm not going to burn through $1k in labor to take it out and put it in again, but I'm open to suggestions for getting it to feel a bit better.
I've noticed the same thing. Lots of people have Clutchmasters stage 3 and report engagement/feel characteristics all over the grid. Different people have different perceptions, but there's got to be someting more to this.
TTBoost and I have driven each other's cars back to back and our engagement points are very similar.
Old Jan 10, 2010 | 08:07 AM
  #33
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
A stage 3 or triple disk with a LWFW will NEVER feel like your stock clutch. I tried all of the tricks two years ago when i installed the ATS triple carbon and LWFW. Nothing will bring it back the a stock feel. Not even altering the slave or master attached to the clutch pedal (did it all). I have had my triple carbon in my car for nearly two years and 4000 miles and still su$k at the line. Yes, you need to relearn how to drive a stick after this upgrade. The good thing is that I stopped racing from a dig and now start at 10MPH to 40MPH instead. It is a lot easier on your car too.
Old Jan 10, 2010 | 08:48 AM
  #34
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
I have the Clutch masters stag 3 in my GT2.I left the DM flywheel in & it feels the exact same as the stock unit except under hard acceleration you can feel the harder bite upon release.
Old Jan 10, 2010 | 09:22 AM
  #35
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
Originally Posted by aroonkl
That's where I got CM stage3 from, Dan@Vivid.
Any idea what are we talking about? Have you tried any flywheel other than stock? I just try to figure out how to get engagement point back to stock and still have benefit with light weight flywheel.
I haven't used another flywheel setups other than stock. I bet you , if you use the stock DM flywheel your car will feel just like stock with much better bite. I know 2 others who have done the same setup with stock dm flywheel here and are very happy. Call CM and ask them about what can be done with LWFW.
I have driven the 996tt's with other horrible clutch setups...this is the best and its a no brainer! No adjustments needed , just assembled straight out of box with stock flywheel and its fantastic from day 1 with very few miles of break in.
Old Jan 10, 2010 | 09:25 AM
  #36
Clarifying my above post, I kept the stock dual mass flywheel and still have the different engagement feel.
Old Jan 10, 2010 | 09:32 AM
  #37
vbmw335's Avatar
Just to make sure , The part # is Model: 20-934-HDF
This clutch has Fiber Tuff coating on the flywheel side on a full face disc , and has the segmented kevlar coating on the pressure plate side for strong holding power.
Old Jan 10, 2010 | 09:53 AM
  #38
robertp's Avatar
If you go with the dual mass fly wheel you loose the quick revs you get from the LWFW (unless you have 700HP). Since I only drive my car on the weekends, I went with the LWFW.
Old Jan 10, 2010 | 01:14 PM
  #39
Boltz.'s Avatar
Boltz. is infamous around these parts
Whats the LWFW+?
Old Jan 10, 2010 | 01:32 PM
  #40
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by Boltz.
Whats the LWFW+?
lightweight flywheel
Old Jan 10, 2010 | 03:44 PM
  #41
robertp's Avatar
This is the reason my first clutch laster 800 miles after the flash (4000 miles total on car). Trying to keep up with this car. With a flash he would still take me by 1 car length. After an exhaust upgrade and super juice, he is one to two car lengths back from 40MPH to 140MPH.
Old Jan 10, 2010 | 04:27 PM
  #42
sharkster's Avatar
I truly do not like the way the clutchmasters stage III single disc applications "feel"- especially with the hydrauic assist in place. With the GT2 slave conversions they are at least more predictable in terms of engagement but you do need to have a strong left leg as the clutch pedal requires a good amount of force to push (also dependent upon the pressure plate option)
Old Jan 10, 2010 | 08:26 PM
  #43
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
My CM Stage III is the same way, not such a fun engagement for anyone driving the car other then myself. I have had it in for over a year and am now used to it. It is a solid clutch though, love how it catches, specially when blipping the throttle. I would like to try some of those mods to get more feel out of it. Do any of them make more of a significant difference then others?
Old Jan 11, 2010 | 03:03 PM
  #44
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
I ordered it and should arrive soon. Will let you know if it helps any?
Old Jan 11, 2010 | 03:14 PM
  #45
aroonkl's Avatar
I'm interested in cutting slave pin idea. Is it possible for DIY?
