Power Problem
Old Dec 15, 2004 | 04:28 PM
Jpcuban's Avatar
The Cuban
Jpcuban is infamous around these partsJpcuban is infamous around these parts
Angry Power Problem
My radio wont work after having to jump the car... power windows are ok but radio is kaaaputt... checked fuses.. all good... does anybody have any info I can go with to solve this problem...
Pressed the power button..... held the power button.. did all but no luck.
I will take it to the dealer but dont want to hassle the trip... thanks for all your help..
Old Dec 15, 2004 | 04:40 PM
TCM's Avatar
TCM
TCM is infamous around these parts
I am not sure if Porsche has the same setup as MB, but MB tend to go into power conservation mode when they have weak batteries. The car will not let you turn on any extra electronic features that are not central to driving the car such as the radio, nav, adjust seats, etc until the battery is back to proper standards. Once back to a good voltage reading, it turns all these functions back on. As I stated, I am not sure if Porsche uses a similiar system, but you may want to try driving the car for a bit and seeing if you can get the radio on then. Hope this helps and please keep us updated.
Old Dec 15, 2004 | 05:40 PM
Jpcuban's Avatar
The Cuban
TCM.. thanks bud I appreciate it.. that is what I am hopeful for... everything else is working.. I am wondering if there is another fuse between the radio and the battery but I dont know that car well enough... hoping someone else will see this and give an answer...
Again.. thanks for your assistance.
Old Dec 15, 2004 | 08:01 PM
Ruftech's Avatar
Ruftech is infamous around these parts
There is a fuse on the back of the radio that will blow almost everytime your car is jumped. You have to have special tools to pull the radio out. Most Porsche dealers sell them. I think it is a 10 amp fuse. Hope this helps.
You will also need your radio code depending on the year of the car. Pre 2002 needs code.
Old Dec 15, 2004 | 08:26 PM
JC996TT's Avatar
JC996TT is infamous around these parts
Fuse on the back of almost all radio's
Old Dec 15, 2004 | 09:52 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
When you try to power up the radio (push the "on" button) do you get an "enter code" message? If so it is a simple matter to enter the code. If the battery is disconnected for any length of time this will also happen. Your radio code should be with your other owner information in the manual folder.
I have jumped my car more than once in the past and the radio fuse has NOT blown as a result.
Old Dec 15, 2004 | 10:14 PM
Jpcuban's Avatar
The Cuban
I bet its the fuse... that I cannot get to.. **** now I have to go to the dealer to have it done.. oh well... I will call them tomorrow...
thanks Ruftech.. I pm'd porschephD for help as well..
I love this forum...
Old Dec 15, 2004 | 11:02 PM
cjv's Avatar
cjv
Moderator
How about re entering the codes?
Old Dec 16, 2004 | 12:58 AM
Jpcuban's Avatar
The Cuban
No power at all.... period.. caput... nada.. nothing...
Old Dec 16, 2004 | 02:33 PM
Jpcuban's Avatar
The Cuban
ok guys.. solved the problem it was the fuse... 10amp fuse to be exact.. now I cant put the stereo back in and the code I put in was wrong so now it says "wait".. I am pissed.. its snowballing but atleast its not the engine....
Old Dec 16, 2004 | 05:59 PM
JP glad you found the problem at least. The code you need is in the seperate manual for the radio. I think it is on a card or something? In any case I had to do this recently and it worked like a charm.
A couple of years ago after some warranty work the dealer had to change out my radio as they said they couldn't get the old radio to take the code. If this happens to you MAKE SURE that you get the new code card.......
Old Dec 16, 2004 | 07:55 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Check under the front hood on the options label. Some dealers write it on there. By the way, where was the fuse located?
Old Dec 16, 2004 | 08:38 PM
Jpcuban's Avatar
The Cuban
hey wardhog.. the fuse is actually connected into the back of the radio. I thought it would be inline with some connection but it was all by itself...
Had to buy some interesting tool to remove the radio... call reus and they helped to get it back in...
still have the "wait" showing on the radio... something screwed up but i will figure it out....
I got away with murder because some guy crossed the cables when they jumped my car... I heard that could destroy cars elect. systems.
Old Jan 22, 2005 | 06:31 PM
Ruiner's Avatar
Jpcuban, I have the exact same symptoms as you did; dead battery, radio won't display any power. I checked the normal fuses, so I would be willing to bet that it is the fuse on the back of the radio. What part did you have to buy? How easy is it to remove the radio?
Thanks in advance.
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Ferrari
Aug 24, 2015 04:35 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
