Passenger window will not auto down 1/4 inch in order to close.
Old Jan 19, 2010 | 12:38 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
I ordered the relay switch from Suncoast, now how/ where does it go?
Old Jan 19, 2010 | 05:30 PM
Billystang's Avatar
Billystang is infamous around these parts
some times if you disconnect the battery for few minutes may work
Old Jan 19, 2010 | 05:48 PM
jpflip's Avatar
More detail please.... Part# you order.
Old Jan 19, 2010 | 05:55 PM
ttboost's Avatar
Did you reset per the manual? If your battery was disconnected or there was a glitch in power, they forget where they are.
Old Jan 19, 2010 | 07:45 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Originally Posted by ttboost
Did you reset per the manual? If your battery was dosonnected or there was a glitch in power, they forget where they are.
I have the same problem on the drivers side, I dont have a manual, anyone know the reset procedure?
Thanks in advance,
Jayson
Old Jan 19, 2010 | 07:53 PM
ttboost's Avatar
Try this:
6452 Power windows
Problem Remedy
The limit positions of the power windows are deleted from
the control module when the battery is disconnected and
connected.
 Manually close each power window as
far as it will go, then press the rocker
switch for closing the window again.
The limit position of the respective power
window is now stored in the control module again.
Old Jan 19, 2010 | 08:46 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
When this happened to me, I manually opened and closed the window fully once (maybe twice) and one-touch functionality came right back.
In my case, I had replaced a battery.
Jeff
Old Jan 20, 2010 | 09:14 AM
Billystang's Avatar
window problem
if i remember correct after you disconnect/connect battery if you turn on the ignition start the car and shut it off ,then start the car again and try the windows,it may work.Good luck
Old Jan 23, 2010 | 08:19 AM
drhenrock's Avatar
part # 996 613 123 00
"Mikroschalter" , I will try the reset also, thanks.
Old Jan 23, 2010 | 08:45 AM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
If that does not fix your problem, it may also need a door lock control module.
We see them kind of regularly- it controls the window drop feature when the door is opened or closed so that the window will clear the seal/roof line. It sounded from your post like that was what was happening. Also, if a window reg is starting to bind, it will affect the window drop feature but you will hear the motor trying to drop the window when the reg is affected. The door lock module is a control unit and mechanical lock in one.
Old Jan 23, 2010 | 08:48 AM
wross996TT's Avatar
Unfortunately, the OPs issue is not a problem with the auto-open and close operation. It is probably the microswitch....start here
Jul 29, 2019 11:13 AM
Sep 1, 2015 03:16 PM
The Oss
Aug 24, 2015 08:19 PM
Aug 19, 2015 06:55 PM
