HELP! How to remove passenger side lower dash cover?!
Old Jan 23, 2010 | 01:48 PM
Astacun's Avatar
Astacun is infamous around these parts
Hi,
I am installing a dension G500 unit in my 2004 996TT Cab and I am almost done except for routing the ipod cable to the cabin (passenger side). I need to remove the passenger side lower dash cover and I don't know how. It is held by 3 plastic screws. I am having trouble removing these. I have tried multiple flathead screwdrivers, quarter, knife, you name it. The screws just won't budge. The notch for the flathead screwdriver is too shallow and I can't get a decent hold of it with anything. I tried forcing one of the screws using a flat kitcheng knife and half of it broke. As I said, they won't move and I am afraid of breaking the foam panel. I am stuck at this step. Any help will be greatly appreciated.
Thanks in advance,
A
Old Jan 23, 2010 | 02:03 PM
Astacun's Avatar
Nevermind. I figured it out. I finally found a flathead tip thick enough.
Old Jan 23, 2010 | 02:12 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
A coin works well in those kinds of thick plastic slots
Old Jan 23, 2010 | 02:24 PM
jpflip's Avatar
C.I.L. extractor...
You should always have a C.I.L. extractor for those situations....
Old Jan 24, 2010 | 12:38 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
So how did the Dension work after you installed it?
Old Jan 24, 2010 | 09:26 AM
Astacun's Avatar
My initial impression is that it works as advertised. However, I haven't had much time to play with it. I haven't tested all the features. I will report back after I use it more.
Perkman87
Nov 19, 2015 05:31 PM
alevine
Nov 4, 2015 10:05 AM
rnl
Aug 26, 2015 02:36 PM
Zero911
Aug 24, 2015 06:51 PM
qbanchin
Aug 24, 2015 10:31 AM
