About to Order HRE Wheels
Old Jan 29, 2010 | 03:55 PM
qvt408's Avatar
qvt408 is infamous around these parts
Hey guys, planning to put a order in for some new wheels. Im planning to order the HRE 593R's. F:19-8.5 with a 2 inch lip & R:19-11.5 with a 4 inch lip. For sure i want a brushed center look but i cant decide on the lip. High Polished or Chrome? Cant make up my mind. Anyone with any input? Thanks in advance.
Old Jan 29, 2010 | 05:28 PM
CoS996tt's Avatar
CoS996tt is infamous around these parts
High Polished, never liked the look of chrome on the 996 imo.
Old Jan 29, 2010 | 06:27 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
If the high polish is not clearcoated, it will start to haze over time and you will need to repolish them. In chrome, there isn't much to maintain... just clean and wipe. The only problem with chrome is that if its chipped/rashed, it can't be fixed and yu will need a new outer barrel. High polish can be fixed but it takes more to maintain
Edwin
Old Jan 29, 2010 | 06:42 PM
qvt408's Avatar
yea very true, ill probably get the high polished outer lip.
Old Jan 30, 2010 | 12:06 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Edwin
Another problem with chrome outers is corrosion under the tire bead. You can't see it but it causes bead leaks. Ask me how I know, I've had it happen three times on three different wheels. It's not only caused by water vapor in compressed air, but by chemicals in the tires. Nitrogen inflation will help but not solve the problem as moisture can also enter from the outside of the bead. High polished outers can also corrode but not nearly as fast as chrome. Previouly I had polished Kensis outers and never had a problem other than spending a few hours every other month polishing them. The preferred solution (for both ease of maintenance and leaks) is high polished outers with a clear powder coat. No bead leaks and low maintenance.
(Sprayed on clear coat will also cause leaks). I currently have Zones with chrome outers. I'm going in next week to the outers replaced with polished/clear coated. The lesson is never ever buy chromed wheels or wheels with chromed outers.
Old Jan 30, 2010 | 12:41 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I have 890R with hidden hardware (inside the center). It is a real pain in the rear that I cannot pump air at gas stations, plus most chucks cannot fit thru the small opening. I believe 593R is also with hidden hardware. If I were you, I'd consider other models.
edited, btw, chrome lip really brings out the look of the wheels, and reflects the center of the wheel and bring out another dimension. IMO, it doesn't matter what the center is but the lip must be chrome.
Old Jan 30, 2010 | 01:47 AM
weoco's Avatar
weoco is infamous around these parts
Go with the look you like... as long as you like it, nothing else matters.
Old Jan 30, 2010 | 10:31 AM
blue911tt's Avatar
blue911tt is infamous around these parts
high polished looks sweet
Old Jan 30, 2010 | 10:49 AM
qvt408's Avatar
Thanks for all the great input guys, Looks like i will be getting high polished with clearcoat.
Old Jan 30, 2010 | 01:54 PM
slick858's Avatar
slick858 has a spectacular aura aboutslick858 has a spectacular aura aboutslick858 has a spectacular aura about
get both. no sense in buying just one set of wheels
Old Jan 30, 2010 | 04:50 PM
qvt408's Avatar
**** i wish, i wonder if HRE will take I OWE YOUS!
Old Jan 30, 2010 | 06:43 PM
jimmy k's Avatar
jimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the rough
I've had a few sets of HRE's on previous cars. When they're new and shiney, it's a great feeling. But somebody is eventually gonna curb those bad boys. And then ur gonna look at that blemish and not enjoy driving ur car as much. And even though u could probably get it fixed for a couple hundred bux, ur gonna get a new car. At least that's what happened to me the last few times.
Old Jan 30, 2010 | 06:49 PM
Turbo Fanatic's Avatar
If you're buying new rims insist on 12" wide rears and at least 8.5" fronts (some have as wide as 9.5" fronts)
You may need to roll the rear fenders (no big deal)
Old Jan 30, 2010 | 07:13 PM
qvt408's Avatar
Actually the 593r has the hardware showing. Are there any advantage or disadvantages getting 12" in there rear . I Would hate to have to deal with rolling my fenders
Old Jan 30, 2010 | 07:36 PM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
How is HRE doing from a quality perspective these days? I had 545's on my Viper and the fit and finish could have been better.
