Techart front bumper install
Hi everyone. For 2 weeks now my body man has been dilligently trying to install an aftermarket (speedgallery) techart type II front bump and rockers. He just cannot get the bumper to fit flush even w/o the inner air duct pieces. We tried to use wire mesh instead and even then, it is not fitting securly around the headlight area. As to the rockeres, cannot get the wide part to sit flush against the car. Please help. Thanks alot.
Snap a clear picture of the car with the bumper off and send it to foresthillexxon@msn.com
I will try to help you as much as I can
Originally posted by vipertestarossa
Yes you will get the bumper perfect, I did
He has to grind away some of the metal support bumper on each side, believe me it will fit !
this is ''Techart'' style not Techart bumper.
Originally posted by 20C4S
Ron,
Ron,
that explains it
I still can't believe that even the true TA bumpers need so much work to fit properly. You'd think if you spend that kind of cash it'd be a perfect fit. I've seen cheap honda kits bolt right up. And the quality ones are usually flawless.
Nissan GTR
Aug 19, 2015 02:11 PM
