Silicone boost hoses
Old Feb 12, 2010 | 04:43 PM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
When installing a set of silicone boost hoses, the install came to a halt when it was time to install the IC to intake hoses as the head of the hose clamp (that connects to the flange) would not pass through the hole in the sheet metal to the IC. Any recommendations here? Use of stainless steel band clamps with a smaller "head", those that look more like a cable tie? Any input is much appreciated.
Ciao, JE
Old Feb 13, 2010 | 01:20 AM
Mr. C4's Avatar
Nobody?
Old Feb 13, 2010 | 01:43 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
i understand you mean the connection between ic and y pipe siliconehose....on ic side it is difficult to fix...you can remove the bumper and do it ....
Old Feb 13, 2010 | 08:02 AM
Mr. C4's Avatar
Bumper was off but I could still not get it done.
Old Feb 13, 2010 | 08:23 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Just leave the stock hoses on they are good up to 30psi.
Old Feb 13, 2010 | 08:39 AM
JeremyS's Avatar
JeremyS is infamous around these parts
You can't preassemble the hose if you're using regular hose clamps. First install just the aluminum fitting into the IC, rest the hose clamp on the same fitting, then slide just the hose through the hole in the engine compartment, slide hose clamp up hose a bit and slide hose over aluminum fitting. Then tighten the hose clamp. It can be a bit tricky to orient the hose clamp to allow proper tightening, but it's not too difficult.
Old Feb 13, 2010 | 09:16 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
or if the IC's already off the car, connect the IC<->hose to the IC/bracket unit first, then slide the hose through the hole, and fix the IC back in place. Helps if the intake box is out of the way.
Old Feb 13, 2010 | 10:26 PM
Mr. C4's Avatar
Tried that but can not seem to get to the hose clamp and tighten it.
Perkman87
Nov 19, 2015 05:31 PM
Boltons991qtr
Sep 20, 2015 06:57 PM
maroli
Sep 15, 2015 07:07 PM
