A night with 28 pounds of boost...
Originally posted by Hamann7
Wow Sharky,
It should be interesting to see how long your car lasts under those kind of boost pressures.
I'm at 1.2 bar and it still makes me feel leery to be running so much boost for sustained periods.
Wow Sharky,
Originally posted by 996TTR
CJV,
Sounds good. They are doing it as we speak.
CJV,
It should say: 996 110 630 73 or 996 110 631 74. Ask your dealer to make sure these aren't the OLD style hoses and that you need the newer stronger ones.
I am also running a setup similar to this and have still not been able to stop hoses from blowing off. I have change DVs and two hoses and still cannot figure out where other leaks are. Hopefully today it will be resolved. Even with the leaks its still running prettty strong.
Make sure you use extra T-clamps that are stronger. That's what I did during the install.. and so far so good. Until I did that, hoses were coming off
