Rear noise when make hard left turn
Old Feb 21, 2010 | 09:01 AM
carnut996's Avatar
carnut996 is infamous around these parts
I know there have been discussions regarding clicking noise but mine is a little different. When I make a hard left turn, occassionally I can hear rear grinding noise sounded like it's either coming from the transmission or something is rubbing on the right rear. I have stock rims and tires. It doesn't happen all the time. Does anyone know what could be causing that? I hope there isn't anything wrong w/ the transmission.
Old Feb 21, 2010 | 10:39 AM
landjet's Avatar
Stock or modified suspension?
Old Feb 21, 2010 | 11:23 AM
got2's Avatar
got2 is infamous around these parts
if you rule out rubbing, it's likely the wheel bearings.
Old Feb 21, 2010 | 12:40 PM
carnut996's Avatar
I have stock suspension.
Old Feb 21, 2010 | 01:48 PM
irysfan's Avatar
irysfan is infamous around these parts
The diff working hard? It could also be the tire rubbing against the wheel well but that happens usually when lowered or with aftermarket wheels with wrong offset.
Old Feb 21, 2010 | 03:26 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Right rear wheel bearing is a good possibility.
Old Feb 21, 2010 | 03:34 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Al funny you say that, we just installed 4 fresh wheel bearings... they didn't sound or feel like they were gone, but when 2 were removed (can't remember which one) they were shot and virtually disintegrated... we just thought it was best to change them as they have not been done in 4/5 years
Old Feb 21, 2010 | 04:59 PM
carnut996's Avatar
I will take the right rear wheel off and do the wiggle test to see if that's it. Will let you guys know what I find out. Thanks!
Old Feb 21, 2010 | 05:01 PM
Al Norton's Avatar
Wiggle test is not valid.
Old Feb 21, 2010 | 05:38 PM
carnut996's Avatar
What is the best way to test wheel bearings other than taking them out?
Old Feb 21, 2010 | 08:40 PM
Hayabusa's Avatar
Hayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to behold
http://www.youtube.com/v/oGZxaDKmtwE&hl=en_US&fs=1&
Wiggle room
Old Sep 3, 2010 | 07:54 AM
tomjack's Avatar
tomjack is infamous around these partstomjack is infamous around these parts
Carnut- Did you ever find out what was causing that grinding/vibration earlier in the year? My car is doing the same thing now. Thx.
Old Sep 3, 2010 | 09:53 AM
carnut996's Avatar
I didn't. I replaced the wheel bearings on both sides and it didn't help. The next thing I was going to try is the transmission mount. I haven't had a chance to take it to the dealer to have them looked at it. Will keep you posted.
Old Sep 3, 2010 | 10:17 AM
Al Norton's Avatar
I replaced both rear half shaft bearings and that did the trick. I haven't read all this thread and it may've already been mentioned but bad clutch release beraring or pilot tube damage can also give grinding noises.
MAcarbon
Mar 6, 2017 08:16 AM
Perkman87
Nov 19, 2015 05:31 PM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
