Weight loss program started with spare delete
Old Dec 30, 2004 | 07:35 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Viper...did you take the carpet out yet?
Old Dec 30, 2004 | 07:48 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
No Eric, carpet is still in
But you just planted the seed
BTW, I'm not sure if you know this but I am Ron from Forest Hill Exxon & Performance
Old Dec 30, 2004 | 08:07 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
Removing the sound deadening material would be fun too since it should produce more aural satisfaction.
Old Dec 30, 2004 | 08:44 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
Drill dollar sized holes into the body and turn it into a space frame. That'll save you several hundred pounds.
Old Dec 30, 2004 | 11:50 PM
Arm's Avatar
Arm
Arm is infamous around these parts
Re: Re: Weight loss program started with spare delete
Originally posted by ben, lj
I heated my GT3 seats when I had them and you can paint the backs too. You'll save 64 lbs, but more importantly the car will feel more gokartlike and you will receive a lot more communication from the car through the less padded seat bottoms. Not only that, the lateral support on the stock seats suck **** and cause you to use the steering wheel to hold yourself up in higher g corners.
Are the GT3 seats height adjustable?
Old Dec 31, 2004 | 08:37 AM
ben, lj's Avatar
Senior Member
Re: Re: Re: Weight loss program started with spare delete
You mean easily everytime you want to (like easy as moving em forward and backward)? If so, no.
The Oss
Aug 24, 2015 08:19 PM
TheInfamousDrew
Aug 19, 2015 12:45 PM
