Need claification for where rear ride height is measured?
Old Mar 5, 2010 | 04:30 PM
smithk3933's Avatar
smithk3933 has a spectacular aura aboutsmithk3933 has a spectacular aura about
Trying to establish where my 01 TT is setup as far as ride height. In checking the Porsche Repair Manual it describes taking the rear measurement as follows:
Measure from wheel contact surface to the locating bore in the rear−axle side section (between toe and camber eccentrics)!
There is a photo in the manual which shows the rear subframe and two holes separated by around 2". One hole is flush with the subframe and the second is a raised hole approximately 10mm.
Can someone tell me if the measurment is supposed to be from the bottom/lowest point of the raised hole(what appears to be the case in the photo) or the flat portion of the subframe between the holes? From the former location I'm at 128mm.
Thanks.
Old Mar 12, 2010 | 12:26 PM
Adam@TopSpeed's Avatar
Adam@TopSpeed is infamous around these parts
Rear measurements are taken near the crossmember on both sides. Using the points with the "holes" mentioned, measure the shoulder and not in the "hole". The fornt ride ht. is measured at the front tuning fork bolt heads.
Hopefully that helps.
Old Mar 12, 2010 | 03:22 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
This?
Old Mar 12, 2010 | 05:31 PM
Those would be the ones sir. Snap gauges make it easier for an accurate measurement. On a level surface with tire pressures set to preferred psi. Consistent points for both 996 and 997.
Old Mar 13, 2010 | 04:58 AM
Mikelly's Avatar
Ding Ding Ding...
To the OP, you might want to check your PM... I sent you a link to the FSM that has ALL this info in it.
Mike
Jul 29, 2019 11:13 AM
pshep138
Sep 1, 2015 09:45 AM
tkeck3
Aug 25, 2015 02:52 PM
Aug 19, 2015 06:35 PM
