How hard is it to take out the drivers seat?
Old Mar 12, 2010 | 08:13 AM
Hedonistic's Avatar
Hedonistic is infamous around these parts
I'm looking at getting the seat repaired at a local shop but didn't want to leave the car there.
Old Mar 12, 2010 | 08:36 AM
ttboost's Avatar
Couple of bolts and a couple of electrical connectors. MAKE SURE to disconnect your battery or you will have an airbag CEL that can only be reset by the dealer unless you have Durametric.
Old Mar 12, 2010 | 09:48 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
if i recall correctly, i didn't disconnect the batt. (but don't quote me on that, double check)
switching on the car's electrical power with the KEY/ignition is what triggers the CEL, in other words keep the key away from the car until the seat's plugged back in.
line the sidestep with a towel, keep mindful of center arm rest area as well. 4 torx bolts
Old Mar 12, 2010 | 09:50 AM
ttboost's Avatar
You may be right. I took mine out at the Texas Mile. I obviously had to drive it. If it sits the whole time, I think it should be fine.
Old Mar 12, 2010 | 08:32 PM
Hedonistic's Avatar
Thanks guys. Especially to ttboost re: warning about the battery or not turning on ignition.
Old Mar 12, 2010 | 09:22 PM
SAVED4IT's Avatar
SAVED4IT is infamous around these parts
I have taken the seats out of my car multiple times. Just don't have the key in the ignition while the seatbelt connector is unplugged and you will avoid the CEL.
The 4 bolts on the seat to the car frame require an E12 or E10 star socket. The tightening torque is 60Nm. Disconnecting the cabling from the seat does NOT require a lot of force. You have to push the edge lock out *while* you pull up gently, kind of a stair step motion.
Old Mar 13, 2010 | 01:43 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Here's a DIY with photos for the operation:
http://quattro.me.uiuc.edu/~jon/Pors...Seats+Rollbar/
Jon
Old Mar 13, 2010 | 04:40 AM
Mikelly's Avatar
I pull mine and install my track seats before each event... You can do it in 10 minutes. But again, don't turn the key on during the removal or installation, or you will be buying a durametric so you can turn the airbag light off.
Mike
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
pshep138
Sep 1, 2015 09:45 AM
pwdrhound
Aug 23, 2015 07:36 PM
