Fuel Pump possibly on way out!!!
Old Mar 14, 2010 | 04:49 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
My Fuel Pump is making a funny noise, it's definitely pump as we pulled fuse and noise has stopped... is it just straight replacement part or an upgraded item etc? Thanks
Old Mar 14, 2010 | 05:01 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Make sure you get the newer/updated pump that replaces the rubber lines with hard plastic lines. I just did this recently.
Old Mar 14, 2010 | 05:10 PM
Mikelly's Avatar
Stevo, Stevo who?? Thought you were quitting on us? Yea, Yea, I know I know... Glass houses and quarts...
Glad to see you posting...
Mike
Old Mar 14, 2010 | 05:26 PM
Thanks, is there a part number for the newer item?
Old Mar 14, 2010 | 06:08 PM
Prche951's Avatar
Stevo, aside from the noise was there any other symptoms?
Old Mar 14, 2010 | 06:25 PM
Possible issues at high RPM
Old Mar 14, 2010 | 07:46 PM
flash68's Avatar
I incorrectly replaced my pump 2 months (turned out to be a boost leak) but at least I have peace of mind that I have the newer version now and it's done.
Pretty sure it's this one I got: 996-620-107-02
http://www.pelicanparts.com/cgi-bin/...0%282001-05%29
Old Mar 14, 2010 | 08:30 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
if you only need the pump itself, buy one used, many had the fuel lines go bad and had to replace the whole assembly and get a new pump just to get the new lines. You can disconnect the pump from the assembly, you might be able to find one in good condition from somoeone who replaced it with low milleage. I don't thing the electric pump itself oftenly goes bad on these, more a trouble with the lines though.
I know i have a perfectly working pump here with a bad hose system... It might end up doing something pretty with the pool in the backyard
Old Mar 15, 2010 | 12:33 AM
Thanks for replies
Old Mar 15, 2010 | 07:55 AM
Prche951's Avatar
the fuel pump is one place where I would not go used when replacing. If that thing fails at WOT 6k rpm, you might just be looking at a new 1000 hp engine build
Old Mar 15, 2010 | 11:49 AM
pumalex's Avatar
I agree but then again, my fuel line failed, just leaking, and i was doing testing at WOT (datalogging) and the ecu saved the engine many times because i was missing fuel pressure (worst than having none i beleive) and the engine pulled timing in order to save the engine. The only symptom i had was something like a misfire so i thought it was the plugs or the tune. And harder i went to see if it would come back. I can tell you that if it was my rotary that had that kind of trouble, it would be long gone.
The ECU on that Porsche is AMAZING... Anyway, just sharing a piece of history
Old Mar 15, 2010 | 12:22 PM
flash68's Avatar
Agreed. I am a miser and all about saving money wherever I can, especially on these labor intensive cars, but once you're in there I can't see not spending the few hundred bucks for a new upgraded pump and call it done!
Old Mar 15, 2010 | 03:15 PM
Prche951's Avatar
aside from hoses, what is the difference in the pumps?
Old Mar 15, 2010 | 05:22 PM
flash68's Avatar
My understanding is that is the only thing. They sure looked identical otherwise.
Old Mar 15, 2010 | 05:27 PM
Prche951's Avatar
ok. that makes sense.
also what kind of mileage do you guys have when replacing pump. I mean miles on the car, 40k, 50k, etc?
