Will headers make much difference ?
Old Mar 23, 2010 | 02:51 PM
XLR82XS's Avatar
Originally Posted by unvmy996
You saw scotts old car with stock headers and external wastegates?
Yep shortly after the new owner took delivery.
Old Mar 23, 2010 | 03:06 PM
Divexxtreme's Avatar
Scot had stock headers to 700 whp or so when he was at 1000 hp, and running external waste gates he had to go with aftermarket headers.
Nope. That car always ran the same, stock headers.
Old Mar 23, 2010 | 03:15 PM
XLR82XS's Avatar
Thanks Scott!
Old Mar 23, 2010 | 06:43 PM
unvmy996's Avatar
Scott so Todd modified the stock manifold to use with external wastegates?
Old Mar 23, 2010 | 06:48 PM
Yep.
I also had stock (but modifed) cams and stock (but modified) heads.
Old Mar 23, 2010 | 06:50 PM
XLR82XS's Avatar
....and did a great job too!
Old Mar 23, 2010 | 07:02 PM
cjv's Avatar
cjv
Moderator
Originally Posted by andymac
I've got a remapped 996TT with a Fabspeed Gen3.
Will upgrading the headers make much difference?
If so which ones should I go for
Cheers
With your set up you would be better off spending your money elsewhere. In addition, if the headers are designed correctly just putting them on will lean your motor. Which means you need to add fuel to benefit from the header install.
Here are the headers we are using on a 4.4L 996tt.
Old Mar 23, 2010 | 07:15 PM
Ya, it worked out pretty well, huh?
Old Mar 23, 2010 | 07:33 PM
AlexN's Avatar
AlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud of
All the answers in this thread seem to be focused on the power and there seems to be a very clear answer on it.
But what if the goal is to focus on reducing lag and better throttle response?
Will aftermarket headers be of an advantage in this case?
And what about thermal coating to the hot side of the turbo and the headers? anyone done that before?
Old Mar 23, 2010 | 09:25 PM
unvmy996's Avatar
Originally Posted by Divexxtreme
Yep.
Hmm .. I had asked tod about doing the same thing back in the day and he advised me against it and just to do headers .
Old Mar 23, 2010 | 09:49 PM
It's easier and cheaper alter stock headers.
I do not recommend it on high hp cars.
I actually went with a custom v band version on my own car and Todd (currently is tuning my car) said the car is super responsive for a hta35r turbo.
We will know more soon after the dyno tuning is done.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 23, 2010 | 10:37 PM
unvmy996's Avatar
I alsolnow that cutting into that cast
manifold and welding on flanges for the externals is a big pain !!
Perkman87
Nov 19, 2015 05:31 PM
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
ModBargains
Aug 20, 2015 12:28 PM
oddjob142
Aug 19, 2015 12:27 PM
