For geeks only!
For geeks only!
So... doing a few pulls to check out the turbos, and I get the PSM/ABS lights, and the Durametric tells me I have a bad MAF. Thinking about the Porsche equation, then:
PSM + ABS = MAF
I had to figure out a set of numbers where each letter stands for a unique integer that fit the equation. All you geeks out there have done these puzzles before. There is at least one solution.
I think I need some track time real bad!
PSM + ABS = MAF
I got the same problem last night.
But it recovered after I restarted soonly. Mine is 02 996 TT.
The dealer told me that the ABS and PSM were triggered or powered by MAF.
So... I got the MAF problem also.
They said it is because of the air filter ( Kn'N ). If I change it back to the original one, it won't happen again. But I think I could stay with it, untill it really doesn't work.
I'm advising don't get used to it - find the problem and fix it.
BTW, the solution to my math problem above, which drew ZERO responses, is
417 + 321 = 738
Jon
