Porsche replaced engine
Old Jan 10, 2005 | 07:39 AM
neil.schneider's Avatar
neil.schneider has a spectacular aura aboutneil.schneider has a spectacular aura about
The engine in my 911 is going to be replaced by porsche. Does this increase the value, decrease the value or does it have no change in the value?
Opinions?
Old Jan 10, 2005 | 09:10 AM
TT Surgeon's Avatar
What happened? RMS?
Old Jan 10, 2005 | 09:22 AM
Consuming a large amount of oil. Cylinders 4 and 6 are showing reduced compression. 225 instead of 275 I was told. I don't know if 275 is accurate or not. I assume this also makes my car a lot slower. Maybe someone could speculate on the decreased performance, or what I could expect after the repair.
Old Jan 10, 2005 | 09:56 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
In my experience it doesn't affect the value. Any buyer gets an engine with that much less mileage on it. How many miles are you at now?
There could be oil fouling the valves and causing the loss of compression since they're not seating properly. Just one man's opinion...
As for after the repair, you'll have to break in the engine, which is a bit of a pain. Otherwise, the car should be better than before!
Old Jan 10, 2005 | 10:05 AM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
How much is "comsuming a large amount of oil?" I go through about a quart every 1-2 months...
Old Jan 10, 2005 | 11:05 AM
TT Surgeon's Avatar
Mine also uses 1qt/1500mi, recently diagnosed w/ RMS, set to take it in Tuesday, I've asked them to do a compression check as well.
Old Jan 10, 2005 | 12:02 PM
20C4S's Avatar
Re: Porsche replaced engine
Opinions?
hard to say. if in the future u're going to trade it in for something else then u don't have to worry about decreasing the value. however, if u're going to sell the car privately the interested buyers can run the VIN to get the car's service history. this might affect value. be sure to keep all the service paper work handy.
Old Jan 10, 2005 | 12:29 PM
OK let's see.
2 quarts every 200 to 400 miles.
I want to keep the car a long time, but concerned over loss of value due to replaced engine.
I think the use of oil coupled with the stain on my garage floor and the loss of compression= problem. Clearly not normal.
Old Jan 10, 2005 | 12:34 PM
20C4S's Avatar
neil,
since u're going to replace it anyways just don't worry about the value. enjoy the car is the most important thing now. u will be questioned but i don't think it's gonna hurt anything.
Old Jan 10, 2005 | 12:43 PM
jaykla's Avatar
ok neil,
that is a lot of oil..i feel better now
Old Jan 10, 2005 | 12:50 PM
Originally posted by jaykla
ok neil,
But I don't.
Old Jan 10, 2005 | 02:04 PM
ebaker's Avatar
ebaker is infamous around these parts
If the engine has a lot fewer miles than the chassis I'd think it would increase the value of the car.
Old Jan 10, 2005 | 02:15 PM
whmarr's Avatar
whmarr is infamous around these parts
Does it give a salvaged title?
Old Jan 10, 2005 | 02:16 PM
MBailey's Avatar
It would not bother me as long as the work was done well.
Old Jan 10, 2005 | 02:53 PM
No salvage title, I believe.
If you were buying a car and they told me the engine was replaced, it might raise flags and cause me to hesitate and perhaps look to another car.
In other words, if the two cars were identical(one with engine replaced one with original engine). Both with low miles. I would want the car with no history of problems. Right?
