Recommendations for 60k service in Atlanta
Can anyone recommend a good Indy shop in Atlanta to get the 60K mile service done on my car? I recently picked it up with around 54K miles and would like to start clean.
I assume, fluids, filters, & plugs will be changed. Anything else (like coils? MAF?). What should I expect to pay.
Thanks.
Thanks.
Call Brian at EPG Atlanta, he is great and could do all of the maintenance required. Here is what I would do if it were mine.
-Change all of the fluids (most can be done at home). Front diff, tranny and rear diff using the Mobil 1 Delvac fluid.
-Plugs-this is a royal PITA but you could probably do this as well if you want. Make sure to check the coils as they may need to be replaced.
-check the other wear items like brakes which are also easy and don't forget to flush the fluid.
-Change your air filter
This is about it.. I know I am probably forgetting a few things but these cars are pretty durable. Congrats on the purchase.
Brian
Brian
ECS Tuning - VW
Sep 2, 2015 09:03 AM
