$550 fuel pump??
Old Apr 21, 2010 | 02:50 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Angry $550 fuel pump??
I cant believe the fuel pump is $550. Has anyone been able to source a cheaper solution/route? I need this since my TT has lost fuel pressure from the pump and won't run anymore.
Old Apr 21, 2010 | 04:25 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Porsche, everything is expensive !
Old Apr 21, 2010 | 04:30 PM
XLR82XS's Avatar
Where did you look? Suncoast? Pelican? My first try would be Suncoast.
Old Apr 21, 2010 | 04:35 PM
enoyskt's Avatar
Suncoast is alot cheaper FYI. Thank you
Is this a job a novice at home mechanic can do including fuel filter?
Old Apr 21, 2010 | 04:56 PM
XLR82XS's Avatar
The pump, yes. Filter, not really. I believe it's located at the left side of the engine bay behind coolant tank cap(s).
Old Apr 21, 2010 | 08:36 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
Filter replacement is not difficult, you just have to work in some pretty cramped space. It makes it a lot easier if you drop the engine down a couple of inches, but it can be changed without doing so.
Old Apr 22, 2010 | 01:25 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Have you taken apart the sender unit in a tank? There is a small piece of hose that is frequent to go out and cause this. I'd look into that before the pump. Do a search I've seen a couple of posts here on this subject.
Old Apr 22, 2010 | 08:10 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
even if it is the hose that went out, he has to change the whole unit because Porsche won't sell just the hose. You want the hose? You need to buy the fuel pump with it...
Old Apr 23, 2010 | 07:16 PM
adam699's Avatar
I'd just fabricate the hose.
Old Apr 24, 2010 | 06:41 AM
pumalex's Avatar
yeah thought about it but then if it fails at one point, it might fail somewhere else due to age and fuel starvation was not something i wanted to mess with, especially since it is very hard to find a good hose to go in the tank, always soaked in fuel.
And there is a lot of hose in the tank, one heck of a spaghetti.
adnanm3
Nov 22, 2023 02:43 AM
pwdrhound
Sep 13, 2016 10:44 AM
XLR82XS
Oct 5, 2015 07:02 AM
