help me figure this out
Old Apr 24, 2010 | 07:17 PM
DNugget991GT3's Avatar
guys,
how do i wire the backup camera for my navigation system ?
i cant see how i can run the video wire from the back bumper, to the back of the navigation unit....
how did you guys do it ?
Old Apr 25, 2010 | 01:46 PM
thanks guys
Old Apr 25, 2010 | 02:44 PM
BIGMONKEY's Avatar
BIGMONKEY is infamous around these parts
i'm not sure if the "thanks" was sarcastic b/c no one responded, or real because someone pm'ed you?
anyway, here's how i did:
in the rear bumper at the site of the license plate, there's a hole. i inserted the wire from the camera into the hole and fished for it from the trunk (after opening the decklid, of course... i may have had to remove that metal piece at the edge of the trunklid right behind the airbox, but i don't think so).
From the inside cabin, I removed the flat trim piece that runs underneath the rear window (just pull straight back). I also removed the rear wiper. that gave me space to pull up the carpet with attached foam. I also removed the c-pillar trim piece to give me more space (and also to run the wires, which i'll get to later). On the rear passenger side, under the carpet, there is a grommet with an opening into the trunk. I inserted the wires from the headunit through that grommet/hole and then fished for it from the inside of the trunk. (I taped the wires to a straightened coathanger and then pushed it through the grommet/hole to get the wire through). I simply then connected those wires.
From the headunit to the trunk, there are probably 2 ways to run the wires. One way is to go along the floor under the carpet. The way I did it was by running the wires along the a-pillar then c-pillar. I chose the driver's side, since I was sitting there when I did it, but the passenger side may be better, since the grommet/hole is on the passenger side.
Sorry I don't have pictures, but I hope this helps. Feel free to ask me if you have any questions or issues!
good luck
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
SteveH
Oct 6, 2015 10:05 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
drkbrent
Oct 1, 2015 07:30 AM
