Direct Port Methanol Injection
Old Apr 30, 2010 | 07:35 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Has anyone installed a direct port system? I have my motor out and with all the recent talk of certain cylinders running leaner than others I was thinking of switching from my 2 jets in the Y-pipe to a direct port system. This would assure equal distribution to all cylinders. I am not sure about how the install would go being that the intake manifold is made of plastic? Thoughts?
Old May 3, 2010 | 07:42 PM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
this is the best way to increase octane u ll fine some useful infos here http://www.alcoholinjectionsystems.com/
Old May 3, 2010 | 08:19 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Don,
Give my friend Jeff a call (707) 685 6279, he will give you the skinny on this.
The reason I have my jets on the intercooling outlet end tanks is to ensure the best possible mixing before the air enters the motor. Also spraying on the end tanks will provide excellent evaporation when the hot weather hits.
Sure direct injection into each runner would be best but that is more complicated and costly of course.
Ben
Old May 3, 2010 | 08:42 PM
cjv's Avatar
cjv
Moderator
Foeget it unless you want to spend a ton of dollars.
Old May 3, 2010 | 08:52 PM
dgreen78's Avatar
Injectors are around $20 a pop and a distribution block is cheap.
Kind of a pain to drill into the plastic manifold though.
Old May 3, 2010 | 08:58 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
will cost more for a motor then to do it right.. Which I am not even sure if there is a RIGHT.. Im not a fan of meth..
Mike
COBB Tuning
Mar 29, 2016 09:26 PM
nlakind
Nov 6, 2015 10:15 AM
orbelo
Aug 30, 2015 12:26 PM
