2003 996tt and blue smoke
Old May 2, 2010 | 06:44 PM
Nikkolaki's Avatar
Nikkolaki is infamous around these parts
I recently picked up a 2003 996tt with 45k miles. I noticed after letting car sit for 30-60min I get a puff or 1-3 seconds of blue and I think white smoke on start up. Its happened a few times now but not every time.
Is this normal oil consumption? Or should I have this looked at (still have warrantly). I assume it would be covered...
Old May 2, 2010 | 06:51 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Valve seals is my educated guess. Shouldn't happen on a car with just 45k miles, more like a, hrm wait, every Ford with 60k miles and up.
Old May 2, 2010 | 06:56 PM
ttboost's Avatar
It's normal. Many threads on this. Some cars do it, some don't. Porsche even states that it should/may use 1qt every 800-900 miles or so. Again, some use less to none and some use more. I think it was said it had a lot to do with being a horizontal engine and oil hanging out in places it normally doesn't on other engines.
Old May 2, 2010 | 06:57 PM
unvmy996's Avatar
do you get the smoke every time you start it up? and is the smoke blue or whitish? the occasional puff of smoke upon start up is normal with the porsches .
Old May 2, 2010 | 07:05 PM
Nikkolaki's Avatar
it is definitely blue and not every time. but i cant say for sure as I didnt notice until someone pointed it out...
would it be the turbo bearings?
The oil was recently changed too, maybe overfill...but doubt it as the was a porsche dealer that did it.
i guess it should be covered under warrantly without issue
Old May 2, 2010 | 07:15 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Let the car idle for a bit before shutting down,
20-30 seconds should be enough.
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
I've noticed that if I let the car idle at 1500 rpms for 20-30 seconds before shutting it down (specially if the car's been on boost, even part throttle boost), I get no smoke 99% of of the time on start-up
Old May 2, 2010 | 07:22 PM
Nikkolaki's Avatar
thanks for the advice.
i started doing the idle cool down based on some reading earlier for proper turbo cool down and notice no smoke...
I will test this out
Old May 2, 2010 | 08:06 PM
Screamin911's Avatar
Screamin911 has a spectacular aura aboutScreamin911 has a spectacular aura about
Mine has 9k miles on it and I've seen it do it. My 02 Carrera did it from time to time as well. So I just figured it was a Porsche thing
Old May 2, 2010 | 08:55 PM
unvmy996's Avatar
i wouldnt worry about it , they all do it mine does here and there.
Old May 2, 2010 | 09:03 PM
_Zac's Avatar
_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future
Mine smokes badly. Most of it comes from the tires in 3rd or 4th gear though.
Seriously no smoke and I own 4 fords. Wait I just sold one make that 3.
Old May 2, 2010 | 10:09 PM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Normal.
Try to let it cool the spool and idle for a minute after boosting and before shutoff.
Also, don't overfill the oil. Guaranteed to do it then especially if you park it with a bit of a nose up attitude.
Old May 3, 2010 | 12:28 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
+1 !
Old May 4, 2010 | 05:42 PM
Nikkolaki's Avatar
it seems to be working...
do you think theres any point to bring it in for warranty work?
or will they say its within spec?
Old May 4, 2010 | 06:06 PM
ttboost's Avatar
A dealer? I think they will tell you you need a new engine and it's not under warranty!!!
