PSS10 ride height?
Old May 10, 2010 | 08:07 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Not sure if this information will help you out or not, but with Bilstein PSS10's your range of lowering is 15mm-35mm in the front, and 0-20mm in the rear.....in relation to stock 996 Turbo height.
hope this helps!
Old May 10, 2010 | 08:12 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Enjoy it!
Originally Posted by pinoy911tt
exactly what i'm going to do. i'm just going to let them settle for a bit then i will corner balance and align it at work myself. i did set the toes when i first put them on but will realign at the same time of corner balancing
Old May 10, 2010 | 12:58 PM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Yup, set ride height first, align second.
I actually weighted the drivers seat when I set mine...
Old May 10, 2010 | 05:13 PM
Finalspeed's Avatar
Finalspeed is infamous around these parts
When I had my PSS10's I had the fronts almost completely lowered and rears had pleanty of room still. I think it is part of the design. Bilstein customer service actually is pretty good. Warrentied my rears when adjusters stopped working.
Old May 30, 2010 | 11:28 AM
rossandbeth's Avatar
rossandbeth is infamous around these parts
Hi,
Just had PSS10 installed, ride height not adj yet.
I'm measuring 25, 3/4 rear & 25, 1/2 front
(edit)
Also hearing the clunk especially on dirt roads.
--Ross
Edit: Clunk fixed today, drop link became loose. When I checked with wheel off it may have had weight on it so I missed it, checking it with wheel on it was rattling.
Old May 30, 2010 | 12:45 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
check if they installed the rubber gasket between the top of the spring perch and strut tower bearing plate
Old May 30, 2010 | 02:51 PM
Prche951's Avatar
endend up buying pss10 and installed them today. something odd about the front setting i'm confused with. it is at it's lowest setting for height but it sits at about 25 1/2 on the front and i can't go any lower cause the collars are at the very bottom is this because i installed the top strut bearing mount metal plate with rubber bushing and the provided rubber bushing that came with the kit? i have no noise complaints at all. all quiet at full turns or going over bumps. just thought i should be able to lower it more any one know. maybe take out the rubber plate bushing that was provided?
use the provided bushing not the stocker. The stocker is thicker and not designed for the pss10. I have the pss10's I have them halfway setting and I am at 25.5 inches in front as well and I am halfway through my setting, so I can go about 13mm lower. However, I am running Nitto INVO's which measure 26 inches in diameter. So I sit higher than the average car with these tires by almost half an inch.
Old May 30, 2010 | 03:28 PM
pinoy911tt's Avatar
i'll do that. thanks
Old Jun 2, 2010 | 01:28 PM
blue911tt's Avatar
blue911tt is infamous around these parts
I like the height of your car. Saw your car in front of Rector when I brought my Lapis blue tt in for service today.
Old Jun 2, 2010 | 01:40 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
That's one bad-a$$ silver Porsche!
Old Jun 2, 2010 | 08:28 PM
pinoy911tt's Avatar
thanks i'm in the process of putting the same set up on ms4cd clean mystic grey turbo
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
Sep 28, 2015 02:19 PM
