Launch Baby Launch! New Launch Control by Vivid Racing
Old Apr 25, 2012 | 07:25 AM
  #46
johnspeed's Avatar
Originally Posted by ari
As cool as this tuning option may be, it's not the same as the factory 997.2 launch control. The factory launch control is integrated with the traction control and can feather the throttle based on the amount of traction the computer sees.
It would nice to experiment different launch rpm points... 3,000, 3500, 4,000
You can significantly reduce wheel hop or axel tramp by shock/spring tuning and with stiffer engine mounts.
That said, let's not simply point out the negative side of this "extra". Epl and softronic are the only two tuners so far with this option from what I know
My Protomotive tune has it..
Old Apr 25, 2012 | 07:29 AM
  #47
johnspeed's Avatar
Originally Posted by Prche951
I don't think that would work. If psm senses too much traction loss, then it will put you in limp mode, just like if you had too much power and I bet that with a tuned 996 or better it will put you in limp mode fast.
...You are right...I have left it on by mistake and didnt hardly move...
Old Apr 25, 2012 | 10:08 AM
  #48
Feelgood MD's Avatar
Feelgood MD is infamous around these parts
Originally Posted by 602996TT
It was a smooth launch considering it was at 5200 rpm's (I also understand this is not the greatest thing for are drive-trains hence reason why I only have done this once.) When I side-step my clutch I let it out in a controlled manner, letting off the clutch completely is way more violent IMO.
oh, i've always considered "side stepping" the clutch where you have it fully depressed, then move your foot over to the left and simply letting the pedal drop out. so even with a smooth, yet rapid, clutch release it still felt pretty violent? hmmm, that's a bummer... that leads to my next question...
"it" = PSM? are you saying you're supposed to leave PSM off when using launch control? i couldn't tell from the video whether it was on or not. btw, i meant launch control earlier, not traction control/PSM. so with the promotive flash, are you dropping the clutch or letting it out smoothly yet quickly? and do you have the PSM on or off?
and lastly,
i'm not hating on it. in fact, i'm totally mesmerized by it and as i've been researching an ECU flash, i want to know if this is a worthwhile $300 add-on. it'd be awesome for a drag strip or lining up with one of the [unsuspecting] italian supercars i see periodically around ATL...assuming i can make it work with out damaging the car. but if it's too violent and going to break stuff, i'd save the $300 and not even bother with it.
Old Apr 25, 2012 | 02:50 PM
  #49
johnspeed's Avatar
Hi,The 'it' is the PSM... and it has to be off..
Know matter how I let the clutch out, I get a wheel hop after its out in 1st gear, as I think it is due to just hooking up at those RPMs or the way the drive system responds??..
Its hard to get a perfect launch on the street even with out using the launch set-up..Most of the time I get some kind of hop coming of the line hard...Feathering the clutch and getting the right RPMs is an art..
Old Apr 25, 2012 | 02:59 PM
  #50
vividracing's Avatar
So who wants to buy this and actually use it?!
http://www.vividracing.com/catalog/-...o-p-45747.html
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Superaudiofreak
Sep 4, 2015 03:22 PM
MrMiggy
Aug 21, 2015 06:55 PM
