Steel pipes crushed near right hand front jacking point ???
Old May 23, 2010 | 11:48 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Hi all,
Any help please on this topic as I have found that a trolly Jack has been used to jack the car and damaged a pipe. Front right jacking point.
There are 2 steel pipes one about 10mm and the other about 16mm ( ish)thet run together.
The large one has been flattened by about 30%.
Any ideas on what the pipe is for. No leaks that I can see.
There are no pipes close to the left hand front jacking point.
Cheers in advance,
Frank.
ps still waiting for my Turbos to be completed.
Oil & vent pipes all renewed. Long story.
New plugs, drive belt, oil change, new discs & pads all round, fluid changed..... the list goes on. Still needs the centre rad changed, bottom row corrosion.
As with most things on my car corrosion is a big thing.
Frank.
That all!
Old May 23, 2010 | 11:51 AM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
that's probably your a/c lines
Old May 23, 2010 | 11:55 AM
Cheers,
Do you think it will cause a problem? Large bore pipe not crushed flat, more oval with a dint in the middle. Small bore pipe untouched.
Frank
Old May 23, 2010 | 11:04 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
not sure on location, but there's chance these are oil cooler or coolant lines.
Old May 24, 2010 | 01:39 PM
David C's Avatar
David C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to all
Embarrased to say I did the same thing.
After setting a jack stand under the pad I went to the other side and lifted there. The chassis is so stiff that the car lifted off the jack stand. It slipped sideways and I did not see it. When it settled back down on the relocated stand it crushed the pipes.
They are AC liquid and suction lines.
Cost me about $600.00 if I recall correctly.
Old May 24, 2010 | 01:48 PM
Luna's Avatar
Luna is infamous around these parts
Wow! I had the same issue happen yesterday! Not really emarrased since we all have to learn by our mistakes or by other morron's mistakes.
I had the car on stands, when putting it back down the front jack stand seemed that it had moved and it flaten one of the rear brake line (Driver side).
I ordered the line today for 46 bucks...
Old May 25, 2010 | 12:51 AM
Thanks for the replies,
The pipe is the Aircon return form the aircon rad.
As most have said, if its working leave it well alone. Had a chat with a friendly mechanic at PG, he said as many of you have, that its a common sight and if its not leaking do touch it.
The new pipe is about £85 + vat. Not so bad compared to some items I have already changed. Not including Lab or gass.
Frank
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
