Tech Q
Old Jun 19, 2010 | 08:23 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Question Tech Q
Will removing the engine compartment fan trigger a CEL? If yes, is there a way to fool the system by inserting a resistor to the wiring loom or something similar?
Temperatures over here shouldn't be a problem, highs in the summer hardly go over 25C.
TIA,
Old Jun 19, 2010 | 11:51 AM
VAGscum's Avatar
I would not suggest removing the fan. That fan is to remove the heat from the engine compartment. It is a tight space and any cooling is a good idea. Sensors and hoses will get brittle and fail early with excessive heat. On these cars, heat is you enemy. Just my .02.
Old Jun 19, 2010 | 02:20 PM
landjet's Avatar
I wouldn't remove it either as it cools down the motor after engine shut off as well. Why do you want to remove it?
Old Jun 19, 2010 | 02:25 PM
bbywu's Avatar
Several Y pipe blow through intakes (ie Protomotive) have piping that will not allow the trunk mounted fan to close. I believe those ECUs are reprogrammed to fool the CEL.
Steve Jarvis
Apr 1, 2023 06:49 PM
pwdrhound
Sep 13, 2016 10:44 AM
freddiemac
Oct 7, 2015 11:05 AM
drkbrent
Oct 1, 2015 07:30 AM
rakka
Sep 23, 2015 08:46 PM
