Installed SSK and shift knob slipping
Old Jul 19, 2010 | 12:13 PM
htownbdr's Avatar
htownbdr is infamous around these parts
Installed SSK and shift **** slipping
I installed a SSK a few weeks ago and sometime when I shift into third the shift **** is rising up off the shifter. As in, its not stuck on real tight. Is there some trick to this? Should I have put a little epoxy or something on the top of the shifter to stick it to the shift ****?
thanks for any help.
Old Jul 19, 2010 | 12:22 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
Some shift ***** have a little bolt that needs to be really tight...
Old Jul 19, 2010 | 12:24 PM
htownbdr's Avatar
I didn't see a bolt on there and to remove from stock all you did was pull really hard in an upward direction.
Old Jul 19, 2010 | 12:33 PM
fdorn's Avatar
This type has the bolt - can't find a pic of the other type, but it is my understanding that it does not have the bolt...
Old Jul 19, 2010 | 12:35 PM
htownbdr's Avatar
Mine looks just like the stock version of that one. I like that one better though
Old Jul 19, 2010 | 03:19 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
I replaced mine by pulling straight up, then put the Tequipment **** on (short and stubby). There is a little hex bolt as in the picture above that I thought I had tight enough, but I was getting a little slip and clicking when shifting. I pulled the boot back off, really tightened that sucker down good, and voila - no more issues.
Don't know the solution if you have no tightening bolt though.
Old Jul 19, 2010 | 07:58 PM
htownbdr's Avatar
No screw on mine and didn't want to epoxy it. So, bought the one pictured above so all should be well.
Old Jul 19, 2010 | 08:02 PM
fdorn's Avatar
That is certainly one way to fix it...
Old Jul 19, 2010 | 08:11 PM
fdorn's Avatar
I removed this post because it re-read your original post and realized you had installed an SSK already....sorry bout that
Old Jul 19, 2010 | 08:44 PM
htownbdr's Avatar
I thought so. Told you I liked that one better. . Was trying to talk myself into a different shifter so this was a great excuse.
Old Jul 19, 2010 | 10:46 PM
DJM's Avatar
DJM
DJM is just really niceDJM is just really niceDJM is just really niceDJM is just really nice
I also have the same problem after installing my ssk, and just like you I planned to solve by buying a new shifter
MAcarbon
Mar 6, 2017 08:16 AM
Sep 14, 2015 06:42 PM
orbelo
Aug 30, 2015 12:26 PM
MAcarbon
Aug 19, 2015 04:52 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
