Toluene as a gas additive
  #31
Old 07-26-2010, 04:05 PM
ttboost's Avatar
I use VP CMP in my NA dragbike. I can leave the fuel in all winter with no issues. My buddy left about a gallon of MRX01 in his tank for the winter, come spring he needed a new fuel pump, injectors and a fuel rail.
  #32
Old 07-26-2010, 11:13 PM
Tim941NYC's Avatar
Originally Posted by Speedy996tt
They used to run 100% toluene in tiny 1.3 ltr race motors running insane amounts of boost.
That's correct! that was those HKS boys!
  #33
Old 07-27-2010, 05:59 AM
crazydude's Avatar
crazydude is on a distinguished road
Question
In Canada, we have 94 octane.
What octane is your gas in the USA?
  #34
Old 07-27-2010, 06:19 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
91 in california.
  #35
Old 07-27-2010, 06:30 AM
ttboost's Avatar
93oct most everywhere else with some 94 thrown in.....
  #36
Old 07-27-2010, 08:28 AM
Prche951's Avatar
Originally Posted by MY996TT
I don't know about this Toluene, but I remembered watching a either Top Gear or Fifth Gear show testing with a few different top additives. The tests were no performance enhancement.
the reason being that if you are tuned for pump gas (91-93), adding 100 in there will not help, unless you happen to have less than 91-93 due to bad batch. So if all conditions are right you will not notice much of a gain.
yes but in Canada, you measure octane like Europe which means you have more like 89
I use this for every batch of ms109, so that it is well aerated
I will add that xylene is corrosive so be careful not to get it on paint, same goes for toluene. Better to mix 1 gallon of toluene in a 5 gallon can of gasoline then pour it into your car, just so that you do not accidentally get it on your fender.
  #37
Old 07-27-2010, 11:51 AM
HdiaS4's Avatar
HdiaS4 is on a distinguished road
couple hints for using Toluene or Xylene as additive.
Go to a Sher Williams, setup a cash account and bargain the price. I did that a long time a go, this will lock your price, and I just got two 5 gallon drums at $11 a gallon, Xylene was even cheaper at $9.
Never go over 30% mixture, even if you are using Marvel Mystery Oil. Since this kind of HC have very slow burning speed, you will actually have gas burning on the exhaust stroke if the mixture is to strong.
Go with Toluene if you can, even thou the octane is a bit lower, it is a bit less harmful to the car seals.
Never get too much at the same time, specially Toluene.
Since Toluene is one of the main ingredients in Trinitrotoluene TNT, you will endup on a FBI list.
There is an AudiWorld member that went to jail for buying too much.
So i know the 55 gallons drum will tempted you, but i would stay way.
  #38
Old 07-27-2010, 12:14 PM
Troy Jollimore's Avatar
Troy Jollimore is on a distinguished road
Prche951, heh...Good one!
CrazyDude, speak for yourself out by the oil sands. I haven't been able to find readily available over-91 for the past several years east of Ontario. We used to have 92, but I think it disappeared back in '02 or something like that.
  #39
Old 07-27-2010, 12:31 PM
Divexxtreme's Avatar
Originally Posted by unvmy996
TT dude , do you think ms 109 is abetter race fuel then others since its oxygenated ?
I've ran both; MS109 (105 octane) and Sunoco 104. The Sunoco 104 has always seemed to make my car run better. I also run the Sunoco 100 and my car loves it. I've used VP, Sunoco and Torco fuels, and so far, Sunoco has worked out the best for me.
pwdrhound
09-13-2016 10:44 AM
BLKMGK
05-31-2016 04:32 AM
proTUNING Freaks
10-13-2015 08:12 PM
DGDDS91
09-12-2015 07:17 AM
Quick Reply: Toluene as a gas additive
