What wheel Torque number challenges traction?
Old Jul 29, 2010 | 08:38 AM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
Originally Posted by emadelta86
I have this problem too. My car is stock, but any little imperfection of the road leads to traction issues (nothing bad of course, but I feel it loosing grip). This didn't happen with Continental's.
Are you sure it is becuse of the tires? It can be the suspension or PSM.
Old Jul 29, 2010 | 03:58 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I think it's tires mainly because the car performed better with the SportContact2 tires.
Anyway being RWD without a good coilover system doesn't help I'm afraid..
I have the same problem on hard braking. ABS kicks in way too early.
Old Jul 29, 2010 | 05:10 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
You right it must be the suspension,i have the same problem sometimes and my suspension is not working right.Thanks i know now
Old Jul 30, 2010 | 12:21 AM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Originally Posted by Zippy
245/40/18 & 335/30/18 Toyo RA1s do a really good job of grabbing good clean road surface with my car, even in 1st. Not exactly sure of the AWTQ#, but it should be above 550.
Zippy, what did you have to modify on your TT to make those sizes fit, and do they fit without any issues? What wheels are you using with them? Where did you get the RA1's from? Thanks!
Justin
Old Jul 30, 2010 | 07:35 PM
Zippy's Avatar
Hi Justin, you have to roll the rear fenders (which is actually very simple) and reshape the rear plastic fender liners with a heat gun. A decent amount of negative camber also helps. -1.5' all around should work, depending on ride height. I have BBS Motorsport wheels in GT2 dimersions.
Mike
Old Jul 30, 2010 | 10:14 PM
Turbo Fanatic's Avatar
The reason I asked is because I was on my way in for a retune. The car hit a very angry 510 4WHP and 540 4WTQ on GIACs conservative dyno. That's an honest 660+ crank HP and 700 ft/lb. 2nd gear really rollerskates for a second before the viscous diff kicks in and rockets the car. BTW I'm not talking about powershifting (I don't do that to my car). Just a 2nd gear roll at 2,000 and floor it. It's a total hoot!!!
4th gear pulls like 2nd used to.
Old Jul 31, 2010 | 07:47 AM
paneraiwatches's Avatar
paneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to behold
Old Jul 31, 2010 | 08:49 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
I went from PS2s to Nitto NT-01s and the grip is night and day. Nittos are noisy as hell, they hum like a swarm of bees, but when I mash it, the tires grip like glue. I think I'm right around 575 rwtq, 575 rwhp.
Old Aug 1, 2010 | 07:33 PM
MBailey's Avatar
I went RWD about the same time I hit 600 whp. I noticed severe traction problems with my PS2s all the way though 1st and second gears (ie I avoided flooring it in these gears because it was frightening and very hard on the tires and drivetrane). I changed the coilovers, lowered the car, and put on larger sized Toyo R888s and the problem was solved. She would even hold WOT in first gear! As the R888s have aged they grip a little less but still much better than PS2s. They have even lasted longer than PS2s. They are noisier but I will never go back to PS2s...
Old Aug 2, 2010 | 09:00 AM
rdss's Avatar
Good to know,MBailey and can you compare both tires on a tweestes track no a straight track ??
Sep 1, 2015 03:16 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
Aug 20, 2015 12:17 PM
