TiAL Billet Alpha30 kit ready to go in an E85 996TT at USP!!
Old Aug 14, 2010 | 02:50 AM
  #31
Turbo Fanatic's Avatar
My EVO ICs never went over 50 degrees C (120F) on the dyno 4th gear pulls at 1.3-1.4 BAR. Pretty Impressive.
Old Aug 14, 2010 | 04:53 AM
  #32
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
It depends on the outside temp,if the outside temp is 10 degrees and you're raising the temp with 40 degrees in 4th gear it's not impressive at all.
Stock ic's raises temp with 40 degrees in 6 th gear at 260km/h,I have 9FF ic's and they raise temp with 20 degrees at 260km/h (at 1.1 bar)
Old Aug 14, 2010 | 09:17 AM
  #33
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
correct all matters on outside temp, do you have any logs of that?
Old Aug 14, 2010 | 10:18 AM
  #34
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Congrats Chris and let us know the results,it sounds interesting.
Old Aug 14, 2010 | 12:52 PM
  #35
dominik...'s Avatar
dominik... is infamous around these parts
Those turbos are really great!
http://www.youtube.com/watch?v=psmcpd5PuBw
10.85 ET
Old Aug 14, 2010 | 03:34 PM
  #36
dixie's Avatar
Here you go
Old Aug 14, 2010 | 04:21 PM
  #37
i never asked you.. what turbos was this on? and did you upgrade the intake to the turbos? Also, did you use stock boost hoses?
thanks
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 14, 2010 | 05:02 PM
  #38
dixie's Avatar
thanks
K16/24 at 1.1 bar,didn't upgrade the intake to the turbo's and I use Evoms silicone hoses.(oem hoses won't fit,see picture)
Old Aug 15, 2010 | 02:04 AM
  #39
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Originally Posted by Neil Switzer
Looking good Chris!
One question, is this going to be a E85 only car or a true flex fuel auto tuning 93 pump/e85 setup?
Neil,are the alpha tial 28 used in the P800 package billet turbos ?
Old Aug 15, 2010 | 02:24 PM
  #40
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Good question!
Often times when people hear the term billet they automatically think that the product is superior, and while that may be the case 99% of the time, not all billet turbos are created equally! One of the main reasons we use a billet compressor wheel is the ability for us to make changes to the aerodynamic profile of the wheel itself, which helps our turbochargers spool quicker and provide more top end horsepower than other turbochargers currently on the market.
Old Aug 16, 2010 | 04:45 AM
  #41
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up Flex fuel
Thanks Neil, It can be flex fuel with a program change but customer is hard core doesn't care for that option.
I would be interested in the flex fuel option. Would you use a switch chip ?
Or would the program automatically adjust with E85 detection?
Old Aug 16, 2010 | 07:29 AM
  #42
It could be set up to auto detect the E85 like the GM cars but it would be alot of work to do. You would need a sensor in the tank with a output to the ecu to know the ethanol levels.
Old Aug 16, 2010 | 08:34 AM
  #43
Exactly Chris. Tym has a setup that has been working on the test bench, headed for installation in a couple of different platforms shortly.
Old Aug 17, 2010 | 04:29 AM
  #44
E85
Does the set up utilize a flip/switch chip for both fuels?
Old Aug 18, 2010 | 07:06 PM
  #45
nanokpsi's Avatar
nanokpsi is a glorious beacon of lightnanokpsi is a glorious beacon of lightnanokpsi is a glorious beacon of lightnanokpsi is a glorious beacon of lightnanokpsi is a glorious beacon of lightnanokpsi is a glorious beacon of light
SO when are we going to see some numbers out of this thing?
