My GT2 vs Peter's 3.8L monster
Old Sep 6, 2010 | 07:55 PM
  #121
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Originally Posted by robmd99
Yes, But the AFR were way off! I am upgrading to 100 pound injectors and a few other goodies and then we will try it again but this time I think we will do it in Arkansas with the mad magician.
Robert
heh yea enough fuel with the air does help =)
Old Sep 6, 2010 | 08:13 PM
  #122
Divexxtreme's Avatar
Robert
Good lord, Rob!! I had no idea any of our cars were running that much boost. Way to break new ground, bro. Keep it up!
Old Sep 6, 2010 | 08:49 PM
  #123
BBI ran atleast one car at 42PSI and 15:1 AFR to test their head studs/gaskets/liners n pistons for their 3.8 kit Betim said we tried to blow it up with no sucess
Old Sep 6, 2010 | 10:07 PM
  #124
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Top guns letting us all learn, guys tks!!!!
Old Sep 6, 2010 | 10:20 PM
  #125
iLLM3's Avatar
2.9 bar?!
damnnnnnnnnnnnnnnn
  #126
contigo's Avatar
Experts, which rods do you recomend... To do just rods
Old Sep 6, 2010 | 10:37 PM
  #127
off the shelf pauter x beam need no oil pump clearance
carillo are a bit stronger
arrow are better unsure if they on the shelf solution though
Old Sep 6, 2010 | 11:42 PM
  #128
M275's Avatar
M275 is infamous around these parts
arrow rods. No need to notch the oil pump.
btw, what are the pro/cons of H-beam vs. X-beam?
Old Sep 7, 2010 | 08:07 AM
  #129
Pauter.
Old Sep 7, 2010 | 08:28 AM
  #130
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Scott when will you go to mexico?
Old Sep 7, 2010 | 10:07 AM
  #131
The h beam rods are actually stronger cause the x beam is a fancy I beam
either way if you manage to bend any of these rods youve got other problems or your running 1400+ horsepower
Old Sep 7, 2010 | 05:48 PM
  #132
cjv's Avatar
cjv
Moderator
1400+ hp ......... now you have me worried.
Old Sep 7, 2010 | 06:14 PM
  #133
it is possible local shop has some turbo the size of garbage can lids with enough anti lag matters im sure they could be spooled
but seriously im not sure anyone on this board with a sub 100k build could possibly ona properly tuned engine bend the rods(pauter/carrillo arrow choose your flavor) out of shear power.
Old Sep 7, 2010 | 07:02 PM
  #134
contigo's Avatar
Can rods be changed from the lower part of the engine not diassembling the whole engine?
Old Sep 7, 2010 | 07:16 PM
  #135
the bulk of the labor is getting the pistons off average difference in labor is 33hrs to remove cylinder heads versus an additional 40hrs to remove the pistons due to the way the motor is designed the hardest aprt of assembly is installing the pistons on the rods.
so you can install the rods without removing the crank from the engine block BUT, if your already into the motor for 60-80hrs of labor why not replace the bearings and make sure everything is good on the bottom end rather then cheap out on a 20,000$ build.
