Well A28's+supporting mods+Meth= blown tip
Hey Alex,
What is Ninja Boy's mods? I noticed that the last shift sounded a little strange.
+1!
http://www.youtube.com/watch?v=DaJxycZgmTo
I spoke with Ninja boy and he is happy with the upgraded trans from MKB
WhiteKing has a kit for the trans, ask him!
He has a kit from Protomotive:
"I changed my turbos to the A3076s. Todd K recommended them to me. It is absolutely awesome. 1.4 is a bit too much on pump gas but i was just trying my luck for once up to that limit. Its back on 1.1 now until i get some MS 109 and then i will boost it up to probably 1.6...will see how it goes then...Thanks for ur comment guys"
I see, thx.
sorry to hear that ..
am runing GT30s turbos , i rebuilded my tranny twice
and i did alot of search for upgrade , i found that MKB , swizler and 99f do upgrade but the problem is that you must send your tranny to them which will cost you alot ..
Finally great member here his screen name is ( whiteknight ) sold me upgrade kit .. and i did the installtion in next store .. it was very easy ..
tip is holding fine and i ran 1.4bar with out slipping ..
see my tip upgrade thread
https://www.6speedonline.com/forums/...x-upgrade.html
and i did alot of search for upgrade , i found that MKB , swizler and 99f do upgrade but the problem is that you must send your tranny to them which will cost you alot ..Finally great member here his screen name is ( whiteknight ) sold me upgrade kit .. and i did the installtion in next store .. it was very easy ..
I told you Alex...you're my smartest friend in europe.
Sorry to hear about your box, but if you are into modding it is a blessing in disguise.
As I also have been posting for advice about slippage in 3rd on my 996tt Tip. I did all that was advised. Fluid and filter change but it still slips from 3rd to 4th up changes. That is why I have stopped modding. I am now saving for the MKB upgrade.
I'm not running the same power as a lot on here but its still enough to cause Tip problems.
My car is a K16 car, with a Revo Technic stage 2 tune dyno'd for 1 bar(agressive) on 99/100 fuel. I have a 100 Cell miltek motor sport exhaust par motor sport DV's and a k&N filter.
On the dyno the car was 550 ft lbs torque before the exhaust/cats and DV's so I dont know what it is now. So once the Tip is modded its back to the power mods.
I have changed my WOT gear change for 3rd to 4th by backing off the power a little just as I hit the button to change up. It does stop the slip, but its inevitable, its going to break sooner or later. I also fogett to back off the power as well at times. Ho Hum...
Frank
Frank
Sunny, I dont want to tell you the obvious, but there is a shot in the dark that this is something to look at. Have you ever checked your transmission mount? Mine felt like a slip or bang under load, and it was just a cracked mount. Now it's smooth as glass.
Just a thought
Just a thought
Just a thought
Just a thought
frank
ps its only in 3rd
I always hear ~500-550 from BHT as being the limit, but every time i talk to evolution motorsports, they swear their tips handle much more power than that...
maybe its in the tune...what tune do you have 007?
maybe one of evo guys will post...
007, was there any warning at all to the problems? Some say you can tell the car is slipping and just turn the boost to where it doesn't slip...but it seems in your case and a few others there was instant blow up without warning...any comments are appreciated...Thanks!
I am pretty sure anyone with a tip doing turbo mods realizes they will have to upgrade the tranny once the stock one blows...$6k isn't crazy when compared to a triple carbon 6-speed flywheel clutch etc...
I am quite sure that my 3rd gear clutch packs are fried and probably need to have them swapped out since from what I know the 3rd gear clutch packs are smaller then 1st and 2nd. I am very interested to see if someone can machine the trans to fit more clutch packs.
I want to beef up my unit since I have to spend the money anyway. Even if I don’t increase the power output of my car at least it will handle the power better then the OEM unit.
I will keep you guys updated with what I decide to do.
dhahlen
Nov 5, 2015 12:55 PM
