Rear adjustible control arms
Old Nov 11, 2010 | 12:11 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
very nice, clean work
Old Nov 11, 2010 | 01:36 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Originally Posted by dixie
Anyone knows who sells these locking plates ?
Tarett sells the locking plates
Old Nov 11, 2010 | 03:06 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
Ok thanks
Old Nov 11, 2010 | 04:09 PM
ard's Avatar
ard
Consider toe in a bit lower, towards the 0.02-0.03" range on the rears.
People will say "for track work more toe will help turn in", but for track work you "buy tires for each race".
A
Old Nov 11, 2010 | 06:54 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
A
Can I share your tire budget?
Old Nov 11, 2010 | 08:05 PM
ard's Avatar
ard
Actually I just toss em when they get to 50%....
I'm kidding of course, but pointing out the 'tension' between a perfect track setup and a optimized for tire life setup. Minimal toe for longest life.
Old Nov 11, 2010 | 08:52 PM
landjet's Avatar
I bought mine from RSS.
Who makes that front bumper?
Old Nov 11, 2010 | 10:06 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
Where do the locking plates go?
Old Nov 11, 2010 | 10:39 PM
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
Thanks for the order, glad you got them fast....
Chris Green
Old Nov 12, 2010 | 12:17 AM
GT3 Chuck's Avatar
Administrator
the locking plates go on the eccentrics that are the stock way of adjusting toe...unfortunately, they do not hold adjustment very well...especially under track loads...the plate locks the eccentric so the toe adjustment doesn't change because of movement in the eccentric
Old Nov 12, 2010 | 03:08 AM
dixie's Avatar
It's an oem bumper but I cut some holes in it with a dremel
Old Nov 12, 2010 | 03:37 AM
dixie's Avatar
For people who like to know this is the ride height measured from the ground,it's the same front and rear 64.5 cm.
Old Nov 12, 2010 | 11:38 PM
coastalb55's Avatar
coastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant future
Those are BBC challenge 19 inch wheels,front bumper is oem but I made some holes in it with a dremel
I'll measure the ride hight tomorrow and post some pictures.
Here is a picture from my bumper in front
You are more courageous than I to take a dremel to your car! You must have a steady hand because it came out very nicely. Good job.
Old Nov 13, 2010 | 02:19 AM
Turbo Fanatic's Avatar
Great work! That is awesome. very tastefully done follows the hood lines perfectly
Old Nov 13, 2010 | 08:56 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Very nice front bumper,car looks nice.
