Diverter valve spring rates
Old Nov 17, 2010 | 01:20 PM
996tbo's Avatar
996tbo is infamous around these parts
Hi
I am running K16/K26 turbos,miltek exhaust,silicone hose kit,5 bar fpr,and remap..
My question is that i have Forge diverter valves fitted with standard green springs.
When mapped they could not get more than 1.1 bar of boost pressure, so i am looking at putting the yellow stronger springs in the diverter valves.
Do you think this will make me get to the boost say 1.3 bar?????
Many thanks
Old Nov 17, 2010 | 03:16 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Also a waste gate adjustment will be needed.
Old Nov 17, 2010 | 04:26 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
have you done a boost leak test to ensure the DV's are your reason for this?
Old Nov 18, 2010 | 02:58 AM
996tbo's Avatar
Yes no boost leaks at all, wastegate actuators are set at 1 bar.
Old Nov 18, 2010 | 05:04 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Shouldn't the DV's stay closed while under boost, regardless of the amount of it??
Old Nov 18, 2010 | 05:49 PM
unvmy996's Avatar
i have been told by Tod k that these cars like soft springs in the dv's .
how ever if they are to soft they will open while full throttle.
Old Nov 18, 2010 | 06:00 PM
SamboTT@ByDesign's Avatar
All you should need would be the Actuators tightened. Try a few turns at a time up to 4-5 from the beginning of tension. You should try for 1.2 to 1.3. Is your tune ok for that high boost though? The ecu may pull timing or the throttle body will want to shut if not.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
shifter_
Sep 8, 2015 12:07 PM
