GT2 Slave conversion fluid question
Old Nov 19, 2010 | 05:25 AM
tbarcelo's Avatar
tbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of light
I've got a few questions about hydraulic fluids in regards to the GT2 slave conversion.
On a stock 996 Turbo I understand that the power steering pump/reservoir use Pentosin. The PS pump also has some internal bits that provide boost for the clutch accumulator, right? What kind of fluid is used by the clutch hydraulics (master/slave) themselves ... DOT4?
On a GT2 slave conversion, DOT4 replaces the fluid in the PS pump and reservoir, right?
Do I have all of these points right? So what's the deal with Pentosin? Why is it used in the PS / accumulator system?
Old Nov 19, 2010 | 07:50 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
On the 996TT, the PS and clutch share the same reservoir, fluid and pump. All use (the same) Pentosin.
On the GT2 slave conversion, the PS remains as it was, i.e., uses Pentosin. There is no power assist to the clutch, and all of the clutch fluid and lines are filled with hydraulic oil. I think brake fluid is ok. In the Evoms conversion, they provide a cap for the connector that used to drive the clutch slave/accumulator.
I don't know why they use Pentosin.
Jon
Old Nov 19, 2010 | 08:14 AM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
The clutch master cylinder( under the front hood) gets DOT4 and the power steering pump and system remains with pentosin.
Old Nov 19, 2010 | 08:20 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Make sure you flush ALL of the Pentosin out of the front lines. Even a few ounces of Pentosin will destroy the seals of the new master/slave. Pentosin spilled on any rubber in the car will damage it as well. . .
Old Nov 19, 2010 | 08:32 AM
tbarcelo's Avatar
Okay, I think I'm finally getting it. For whatever reason, I hadn't been thinking about the front hood.
So with the GT2 conversion the PS pump/reservoir sticks with Pentosin. This is a black fill cap under the rear hood near the oil fill with "Pentosin" marked on it, right?
The clutch hydraulics switch to DOT 4. This is a green cap (stock) with Pentosin that gets switched to a DOT4 cap during the conversion process.
Okay, I'm all set now, thanks.
Just curious - in the stock system, do the fluids from the front hood reservoir and the rear hood reservoir intermix? If so, how?
Old Nov 19, 2010 | 08:35 AM
tvurt's Avatar
They intermix when your slave seals fail and the pressure from the PS pump drives fluid back up to the front of the car, and causing a nice mess.
Old Nov 19, 2010 | 08:46 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Can I get an AMEN on that one my brother!!!!
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
