stock, brembo, or stop tech?
Old Nov 21, 2010 | 04:08 PM
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
do i really need to update my brakes if i just hall a-- in the canyon and on the street? i could get a used set of 4 piston, big brakes(stop tech) for $1500. should i just keep the stock ones? front brakes only.
Old Nov 21, 2010 | 04:26 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
you could upgrade your pads, you dont need new brakes unless your having trouble with your current set.
you can upgrade to the gt3 6 piston calipers, or upto any of the better setups PF, Stop tech, Brembo but all of these systems that are better then stock are not cheap.
Old Nov 21, 2010 | 04:27 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Absolutely not, brake pads/fluid will work, but I have 4pot Stoptech ST40 caliper on the front of my '00 S4, track only car, and I love them. $1500 is a great price. I have had mine for 8 years and 1000's of track miles and they are still awesome!
Old Nov 21, 2010 | 05:03 PM
sure they are a great caliper on that car but are they better then OEM on this car, what data do we have larger piston diameter?
Old Nov 21, 2010 | 05:25 PM
mod mike's Avatar
i will know the part # 2moro .. my brakes are fine, just though that was a good deal and we all know how we like good deals on things we will most likely do anyways!. but if i can get away with just upgraded pads, already changed the fluid, i much rather save that $ for some other mod>> i will look up the part 2moro online.. thanks
Old Nov 21, 2010 | 05:39 PM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
If you're not doing heavy track time I say the stock calipers are fine. Get your self a good brake pad, braided stainless steel lines, brake fluid flush with some Motul RBF 600 and depending on the condition of your current rotors maybe a new or upgraded set.
I have a fiend who tracks his TT, Stock calipers, upgraded brake lines, upgraded pads and stock rotors. No problems, no fade.
Old Nov 21, 2010 | 06:06 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Stocks fine I'm sure, but my brembos are awesome! Highly recommend them, your confidence will change even on the street when you know you have some bad *** brakes backing you up
Old Nov 21, 2010 | 07:29 PM
TheVenom's Avatar
TheVenom is infamous around these parts
had stoptech on a couple cars and didnt like em. brembo is the way to do it
Old Nov 21, 2010 | 07:58 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Stock calipers are brembos. Obviously they make bigger kits too, but unless you go to a 6 pot your not going to get much. I recommend a pad change
Old Nov 21, 2010 | 09:31 PM
Turbo Fanatic's Avatar
I think the best bet is 997T brakes. They bolt right on (need longer 997 bolts), come with bigger discs and 6 pot calipers. Pads are readily available and they fit under the stock 18s.
Look around for a takeoff set.. they come around as the 997 guys go to even bigger brakes.
Old Dec 17, 2010 | 09:52 PM
MichaelRay's Avatar
MichaelRay is infamous around these parts
I track my car 15-20 days a year and drive it aggressively on the street daily 9 months out of each year. I good set of pagid yellows on the front with blacks on the rear will give you incredible stopping power on the track with minimal braking effort. You litteraly break with your toes, not your feet. I still run the stock rotors and flush the fluid after each track event. No doubt you can spend more $ on different brakes, but with the right pads and fluid changes, the stock brakes allow you to spend the $ elsewhere.
Old Dec 28, 2010 | 12:55 PM
Ricie168's Avatar
Ricie168 is infamous around these parts
It really depends on how you are using your brakes......bigger is better......right?
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
osj911
Aug 26, 2015 06:41 PM
Zero911
Aug 24, 2015 06:51 PM
