Help! Auto dim rear view mirror failure
Old Dec 4, 2010 | 12:54 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Unhappy Help! Auto dim rear view mirror failure
I go out to drive the turbo today and notice there are tiny droplets and specs of a black type substance all over my painted center console and on the leather shift plate and on both front seats! It looks as if the mirror has some stuff inside it to auto dim it and it has failed and leaked this crap all over my console. Has anyone ever encountered this and if so what in the heck did you use to remove the junk? Goo gone and bug and tar remover have done nothing! Any experience or suggestions?
Old Dec 4, 2010 | 02:12 PM
djantlive's Avatar
that stuff is very corrosive. most likely, it's ruined what ever it sits on.
the fluid is most likely to leak when car gets hot parked under the sun repeatedly. if you decide to get another, make sure you get a windshield screen to block the sun.
Old Dec 4, 2010 | 02:27 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
DUde you always give the worse case scenario diagnosis..lol
Old Dec 4, 2010 | 04:05 PM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
I just replaced mine, luckily, it didnt leak. They seem to be a wear item on these cars as I know of a few others.
Old Dec 4, 2010 | 05:00 PM
djantlive's Avatar
Well, maybe you'll like this alternate reality
"It'll buff right out"
Actually, the mirror design is shared between VW, audi and Porsche. It's a well documented issue. Lambo also uses the mirror which ruins many infotainments and control panels costings $$$
Old Dec 4, 2010 | 06:06 PM
ard's Avatar
ard
BMW too...Known failure mode with the same result- destroyed consoles
Old Dec 4, 2010 | 06:13 PM
silver's Avatar
If you have not replace your mirror then I suggest you get on it fast. This crap seems to have dripped down on the console but also splashed a little onto both seats and some of the lower radio surround. It is a painted silver console with grey seats. The black drops are pissing me off! Oh well I can have the console repainted, replace the carbon tip shifter surround but the seats...... may be time for some new seats, rollbar and harness set up.
Old Dec 4, 2010 | 07:33 PM
smithk3933's Avatar
smithk3933 has a spectacular aura aboutsmithk3933 has a spectacular aura about
Check out the thread I posted on a source for mirror repair.https://www.6speedonline.com/forums/...im-mirror.html
Old Dec 4, 2010 | 11:18 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Odd- mine just failed last week as well. Sounds like I need to replace before it eats a hole through my car. Thanks for lead on new one SmithK
Old Dec 4, 2010 | 11:29 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Rearview Mirror + leaking oil = useless blurred mirror ...
Been there done that ... I think there's a company you can send it to to have it "refurbished" ... I was in the same boat ... went on ebay to get one for $75.00
it was a 5 minute swap...
Old Dec 5, 2010 | 04:19 AM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
There was a period where the manufacturer covered the replacement on the E46. BMW covered under my CPO and replaced the entire console. That stuff will eat through anything.
Old Dec 5, 2010 | 02:53 PM
silver's Avatar
Well great news! After trying many different things you will not gues what finally did the trick. A pocket knife! I had a swiss army pocket knife and took the very tip of it to see if any would scrape off. I found that it would I just had to be carefull not to marr or scratch the leather or the painted console. I used some quick detail spray as lube on the console while surgically scratching each dot with the tip of the knife and used some leather conditioner as lube while doing the same with the seats. The seats came out perfect and the console is a 9.8 out of ten. The tip shifter surround is a lost cause but that is the easiest to replace. It took a litte over an hour or so but came out great. Thanks for the replies guys and now I am happy again as the interior of my car was pretty flawless for an 01 with 23000 miles.
Old Jun 12, 2011 | 07:03 PM
Scott@Radar-Mirror.com's Avatar
Scott@Radar-Mirror.com is infamous around these parts
If your mirror goes bad you should pull it out of the car asap.. the stuff that leaks out is toxic. These mirrors can be fixed by autodimmingmirrorrepair.com
Jul 29, 2019 11:13 AM
Goonie
Sep 13, 2015 02:26 PM
ppwchiang
Aug 20, 2015 10:28 AM
Gewgaw
Aug 19, 2015 11:52 PM
