y pipe removal
Old Dec 29, 2010 | 08:30 AM
raineycd's Avatar
Should be pretty easy once you get the Y pipe out. I haven't personally looked, but should only be a few bolts and wires I would think.
I just looked at the parts diagram and seems it is pretty straight forward.
I saw your other thread, why are they thinking it is the tb? Symptoms seem to point elsewhere I would think...
Old Dec 29, 2010 | 11:31 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
They said they pressure tested it all the way from the turbos ... and they didnt find anything else ... I have a feeling they just wanna sell hardware ...
AND .. it USED to throw codes once in a whiiillleee ....
I got the car last night ... and it has thrown codes at least 5 times ... I really hope they didnt sabotage anything ...
I'll go for a second opinion elsewhere ...
What would you suggest though?
Old Dec 29, 2010 | 03:35 PM
raineycd's Avatar
What are the codes it used to throw?
What are the codes it is throwing now?
Find a buddy and take a few hours and swap tb's and see if it goes away before you spend the $$$. Then paint both Y pipes while they are out! Win win!
Old Dec 29, 2010 | 06:13 PM
John@SpeedTech's Avatar
Ari,
The throttle body is a fairly easy DIY project. Once the Y-Pipe is out, it's only another few minutes.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Dec 30, 2010 | 12:38 PM
Saint Ari's Avatar
Durametric just said ... Hot Film MAF ...
AND .... it says error data from DME or something rather ... what gives ...
Old Dec 30, 2010 | 12:40 PM
Saint Ari's Avatar
MAF is out cleaned with Elec cleaner right now ...
What constitutes a failed tb? I read somewhere that this can be cleaned as well .... ?
Old Dec 31, 2010 | 12:17 PM
raineycd's Avatar
I would probably start with the MAF then if you are getting MAF errors. Don't know how the TB would be the problem unless it is closing too much or has a leak, but I would probably start with the MAF since it is a common issue.
Old Dec 31, 2010 | 02:53 PM
Saint Ari's Avatar
MAF reads about 1.3-1.4V on the durametric ...
I'll go that route though ...
Old Dec 31, 2010 | 03:05 PM
raineycd's Avatar
Probably the first step - if that doesn't fix it probably will be easy to sell it here or on ebay!
Old Sep 1, 2013 | 04:38 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Bumping on old thread. Wondering how you guys get this N75 vac hose off?! Dear lord, what a PITA!! I'm at a point where I just feel like re-installing the damn Y-pipe!! This thing seems impossible to get off.
Old Sep 1, 2013 | 06:48 PM
raineycd's Avatar
It is a pain - they have it clamped on there pretty good. Just get a good pair of curved needle nose pliers and keep wiggling/working it off. You could always cut it and replace it. Probably could use replacing on our aging cars anyway!
Good luck! Zip tie any lines you can when you re-install!
Old Sep 1, 2013 | 07:27 PM
FI_FTW's Avatar
I ended up removing the other end of that small hose; no clamp on that side. Man, this little project took quite a bit longer than expected!
Old Sep 4, 2013 | 05:04 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Chad, what paint did you use? And how is it holding up after nearly three years?
Old Sep 4, 2013 | 09:08 AM
johnspeed's Avatar
A major brand ceramic paint will do the trick...
I painted mine and other engine parts with that type of paint and it will look like new for a very long time,,
And adheres like glue IF you prep the part with brake clean or acetone,,then use fine emery cloth to scuff up the surface..
Old Sep 4, 2013 | 10:19 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
If you decide to do the intake plenum, make sure you lower the engine.
Hard to think I did the whole IPD plenum install without lowering it. At the time, I didn't know lowering it was as easy as 2 bolts.
