Transmission and Diffrential Fluid Change
Old Dec 17, 2010 | 12:42 PM
xcusemi's Avatar
xcusemi is infamous around these parts
Hello:
I did the search and only see people are changing Transmission Fluid. I was wondering whether the Differential Fluid need to change on 996 Turbo? If so, can anyone direct me to the link where I can perform this task myself.
Thanks and happy holiday!
Old Dec 20, 2010 | 09:52 AM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Yes, the diff fluid should also be changed at the same time as the transmission. There's not much to it- use Mobil Delvac 1 full synthetic gear oil- 75w90 weight.
Old Dec 20, 2010 | 10:18 AM
Slider's Avatar
There are a few DIYs on RennTech to get you through these jobs. The transmission one is here, the Diff is close by.
http://www.renntech.org/forums/index...-instructions/
Old Dec 20, 2010 | 10:51 AM
xcusemi's Avatar
Thank you very much for the suggestion. I just ordered the oil "Devac" and should perform the task this coming weekend.
Happy Holiday!!
Old Dec 20, 2010 | 06:10 PM
Nikkolaki's Avatar
Nikkolaki is infamous around these parts
how often do these need to be changed?
LiquidElephant
Aug 27, 2015 06:17 PM
00aston
Aug 27, 2015 12:01 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
