E85 Tuning...
Old Jan 16, 2011 | 06:33 PM
  #106
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Ethanol is highly regulated. Uncle Sam wants to collect their tax dollars. You have to account for just about every drop and have an alcohol permit to purchase it. Maybe you have one. If not, I would be very surprised if a plant just sells it to you without the ATF breathing down your neck.
Old Jan 17, 2011 | 03:52 AM
  #107
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Pretty much what happens here too. We also can't buy/use methanol. And race gas is illegal for street use, and there are no "bio-fuels" available....the country of supercars....6 dollars/gal for some crappy 93oct..
Anyway, I found that the stoichiometric ratio for E85 is 9.87, which is far from the usual 14.8 for 93oct gasoline. And the lower heating value is 29.19 Kj/Kg vs 43.5 Kj/Kg for the 93.
Old Jan 17, 2011 | 11:38 AM
  #108
AtomicZ's Avatar
AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !
Originally Posted by dgreen78
Nice avatar Atomic! Hows it coming along?
The car is done. Flying out to drive it tomorrow. They hit 1584 rwhp and told them that was more than enough.
As far as buying ethanol straight from the plant. On our farms in Nebraska we run well motors on 100% ethanol that we get from the plant just down the road. I need to look into what they will want from me to buy in Minnesota since I don't own a farm up here.
Old Jan 17, 2011 | 11:44 AM
  #109
ttboost's Avatar
WOW!!! Impressive Eric...just staggering...
Old Jan 17, 2011 | 12:21 PM
  #110
hrs1's Avatar
hrs1 is infamous around these parts
Originally Posted by KPG
I am looking to upgrade my car to run on E85 exclusively. Here in MI, it is a tossup as to whether there are more Starbucks or E85 pumps near my house. The reasoning behind this move is as follows: My car at its most recent upgrade did 930AWHP on C16 around 26Psi and currently runs 700AWHP on 93. As much as I enjoy this car, I have very little time for it anymore with family and business commitments. I have spent much time and much more money building this motor only to run it at pump gas levels. I dont have the time, or patience to be swapping fuels and draining tanks. I want to run one fuel only and I think E85 is the ticket. I am not spending another nickel on this car as far as hardware upgrades are concerned,there is nothing left to upgrade, but I am interested in feedback from other members and even tuners on their experiences with E85. I would like to tune the car to the max with the current system I have and then control power via the EBC as opposed to a specific file. My fuel system is good for 1400 HP so it is not a concern. The injectors are 83 lb units and are the same that Joe and Bryant have in their vehicles which are are making 1100 hp or so. I would think this is enough injector even given the 20-30% increase in injector cycle needed for this fuel. The bottom line is I want to drive my car near the power levels it was built to achieve every time I turn the key, instead of rare occasions where I have the proper fuel. I really dont care about the ultimate power number, but if I would like to get 850-900 rwhp( RWD car now) every single day on fuel I can buy locally at the pump. Any input would be greatly appreciated. Thanks! Kevin
I run e85 100% of the time. I can tell you that after the inital cost of conversion, I would def recommend.
Pros:
-50-90 whp increase
-cheaper to fill up
-faster throttle response
-proven (your not a beta test!)
Cons:
-In cold inital start-up a bit harshe and when cruising at low RPMs can feel a bit "boggy" at times
-less mpg, I have gone through tank in a few hours driving hard!
-tough to gauge miles to empty (although this may be due to injector size throwing off trip computer)
-Spark plugs go bad fast (at least in my case one spark plug went bad after a few hundred miles)
-availability (doesnt appear to be issue with you either)
-fuel system mods (doesnt appear to be issue with you either)
Hope this helps!
Old Jan 17, 2011 | 12:30 PM
  #111
ItalianStallion's Avatar
ItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant future
My suggestion is to just run 93 Octane in the freezing winter months, this way you won't have to worry about cold start up. IMHO I believe you will need right around 2000cc injectors. Swap the injectors, pour some E85 in and run it on the dyno for a tune. As long as the temps aren't freezing, you should have no problem with E85 at startup. Even if you do want to use E85 year round, worse case scenario is it will take you an extra 2 minutes getting it started in your driveway. Best of luck!
Old Jan 17, 2011 | 04:04 PM
  #112
AtomicZ's Avatar
You going to make any of the TX events in March?
Old Jan 17, 2011 | 04:13 PM
  #113
ttboost's Avatar
Probably not. But if I do, and it's a big "if", it will be carless...I would like to make at least one event this year, but time will tell... new house, lots of stuff goin on...gotta get the bike ready, still working on the Turbo, blah blah blah...
Old Jan 17, 2011 | 04:19 PM
  #114
AtomicZ's Avatar
It's a long trip - no doubt.
Now back to the regular scheduled programming on E85.
(sorry for getting off topic)
Old Feb 21, 2011 | 08:56 PM
  #115
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
The car is getting its tune this week if there are no hiccups. As far as tuning on the old setup, there wasnt enough injector to do much beyond idle and startup tuning. Then we decided the regular Switzer exhaust wasnt going to be sufficient for an "everyday" 900hp we are shooting for so they made a new 3 " exhaust. Always liked the look of the blow thru as well, so why not. Here we are, ready to go tune some corn oil. I imagine it will be a few days of tuning for startup, idle, part throttle and driveability before they hit the power numbers. We will see....
Old Feb 21, 2011 | 09:27 PM
  #116
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
The car is getting its tune this week if there are no hiccups. As far as tuning on the old setup, there wasnt enough injector to do much beyond idle and startup tuning. Then we decided the regular Switzer exhaust wasnt going to be sufficient for an "everyday" 900hp we are shooting for so they made a new 3 " exhaust. Always liked the look of the blow thru as well, so why not. Here we are, ready to go tune some corn oil. I imagine it will be a few days of tuning for startup, idle,o part throttle and driveability before they hit the power numbers. We will see....
Way to go and about time. You should make some big numbers. GL
Jag
Old Feb 21, 2011 | 09:45 PM
  #117
Prche951's Avatar
Kevin, good move on the E85. I was contemplating this last year, but it's not in the cards for now tuning wise.
when I found out how much more fueling I needed I just about **** a LWFW. The stoichiometric fuel ratio of gasoline is 10 and of E85 is 14.7, so to my understanding calculating the additional fuel needed is 1.47 times your current injector size maintaining the same DC, ...
as a cross reference, a local guy running E85 on another brand of car increased his inj from 42 lb'ers to 60 lb'ers and gained about 10% power across the board. Funny thing is that his increase in injector size matches the ratio above. A 10% power increase in your car would put you where you want to be so it seems. Good luck with this, can't wait to see the results.
Old Feb 21, 2011 | 09:55 PM
  #118
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
+1 on the E85 i'm a lone wolf running E85 out here in SoCal for about 6 months now & loving it especially when i go & fill er up at $2.50 a gall & can hang with all my methanol & race gas bro's
Old Mar 9, 2011 | 05:21 PM
  #119
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Congrats Bro!!!! Is it True 908 AWTQ under 4400RPM 902 AWHP.....with an exhaust.... WTF
Old Mar 9, 2011 | 05:24 PM
  #120
KPG's Avatar
KPG
E85...just doing my part to be eco friendly
