What mods are necessary in order to accomodate a 18x12 or 19x12 rear wheel?
Old Mar 12, 2005 | 10:45 PM
02TurboX50's Avatar
02TurboX50 is infamous around these parts
I need some more traction. Wider rubber and a better tire should do the trick. Who makes 12" wide wheels that will clear everything on a Gt2?
Old Mar 12, 2005 | 11:17 PM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
Its not so much how wide the rim is but having the correct offset. I would also suggest a 18 inch rim if your worried about performance. The bigger sidewall will give some slack for flex in the tire on hard launches. The BFG K/D is by far the best street tire I have ever used, it sticks very well. Make sure your front wheels arnt to wide either. It gets annoying after awile, your front wheels will get stuck in the grooves of the lanes on the highway. Its like driving a train on rails, it will just push your around on the tracks. Check your pm I will find out the widest rim and offset possible for the GT2.
-Daniel
Old Mar 13, 2005 | 12:05 AM
03-turbo911's Avatar
Senior Member
The GT2 comes stock with 12x18" wheels running 315's.
Old Mar 13, 2005 | 03:12 AM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
GT2's come with fenders rolled from factory. You might need to roll the fenders - depends what tires. If you plan on PS2's - A rear roll is definate.
Old Mar 13, 2005 | 08:52 AM
02TurboX50's Avatar
Wow, I didn't realize that it came with 12" wide wheels. That's great!! I wanted to upgrade to a 335/30/18 or a 345/30/18 size tire that is more sticky to give me a larger footprint with better traction.
Has anyone done this?
I know Michelin makes a Pilot Sport Cup in 345.30.18, but I can't seem to find a 335.30.18.
That tire would likely make this car a launching machine because when I had them on my 750hp Viper with 800tq, the tires wouldn't spin in 2nd gear.
Old Mar 13, 2005 | 10:20 AM
ebaker's Avatar
ebaker is infamous around these parts
I'd try 335/30-18 on the stock rims. If it rubs on the inside you might have to use a spacer and longer wheel bolts. You might ask CJV if that would fit. It looks like it would on my Turbo, but I'm at stock ride height. I believe that Kumho makes a sticky 335/30-18 tire that is relatively inexpensive. It looks to me like body work will be necessary to fit a 345 rear tire.
COBB Tuning
Jan 1, 2025 09:02 AM
PenguiN
Nov 12, 2015 05:24 PM
Sep 1, 2015 03:16 PM
TrackOne
Aug 20, 2015 12:56 PM
cab83_750
Aug 19, 2015 12:37 PM
