Remote Key Not Working
My key fob stopped working so I assumed that the battery needed to be replaced. I replaced the battery and the remote door locking function still doesn't work. I can open the door manually and start the engine but the keyless lock/unlock function and hood unlock function don't work anymore. The LED on the key fob flashes as usual but the car does not respond. I have another key fob that works perfectly so I know that there's nothing wrong with the car (i.e. blown fuse, sleep mode, faulty receiver, bad antenna, etc.) Is it normal for these key fobs to go bad? Is there any way that I can revive my key fob?
Was the car sitting for five days or more? The car's receiver shuts down to conserve the battery. Stick the key in the door, manually unlock it, and press the remote button. It should work after that.
Sorry if that's a dumb question...
On the horseshoe surrounding the radio and A/C there are several switches, one to raise the spoiler, turn on and off the psm, and one to LOCK AND UNLOCK the doors. I locked and unlocked several times via this switch. I pressed the button on the remote and I heard the doors lock. Pressed again and they unlocked. Everything has worked fine since.
Please let me know if it works for you
RallyBird
Oct 7, 2015 01:20 PM
pshep138
Sep 1, 2015 09:45 AM
Ferrari
Aug 24, 2015 04:35 PM
