5 to 40% to the front? 996TT
Old Mar 15, 2005 | 05:50 AM
Gilhart Racing's Avatar
Member
Gilhart Racing is infamous around these parts
If you were to disconnect the driveshaft to the front diff. would you still have 5-40% attempting to be sent to the front wheels under rear traction loss?
On the 2wd dyno is 5% always being lost from the rear wheels?
Must you change out the ecu and transmission of the 996TT to that of a GT2 in order to get 100% rear wheel power?
I very interested in the first question as the answer should help with the other two.
Thanks for your help,
Rick
Old Mar 15, 2005 | 06:27 AM
msindi's Avatar
The transfer is mostly mechanical so...if you disconnect the fron diff it should be pure RWD
PSM might still limit power and brake individual wheels if slippage is detected
Old Mar 15, 2005 | 07:11 AM
TT Surgeon's Avatar
Probably won't work very well with the PSM system.
Old Mar 15, 2005 | 07:25 AM
Member
Thanks for the reply's. I forgot to mention this is on my race car and the PSM has been removed and no longer is part of the equation.
I just don't know if the ECU will still try to dictate 5 to 40% to the front even though nothing's there.
I have heard that the system is mostly mechanical but does that mean there is still some loss?
Thanks,
Rick
Old Mar 15, 2005 | 07:34 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Cool
Go Rick!
Old Mar 15, 2005 | 07:53 AM
ebaker's Avatar
ebaker is infamous around these parts
The torque is transferred to the front axle by a fluid coupling. The difference in speed between the front and rear axles determines how much torque the front gets. If the front driveshaft is disconnected, the output shaft from the fluid coupling spins freely, and there is no slippage in the fluid coupling.
Old Mar 15, 2005 | 08:03 AM
Member
Thanks ebaker for the info. Has anyone disconnected and driven their car in this fashion? Anyone track one with the driveshaft disconnected?
Great forum!
Rick
Enemy
Nov 10, 2015 08:01 AM
bmwtmx
Aug 26, 2015 07:26 AM
John@SpeedTech
Aug 23, 2015 12:07 AM
