does anybody run a milltek anymore? advice needed
Old Feb 9, 2011 | 03:29 PM
  #31
sunir's Avatar
Originally Posted by stef@europipe
Sure the Ruf exhaust is quieter but it is also more restrictive.
Here are the backpressure numbers :
Stock exhaust : 0.36 Bar
Ruf : 0.22 Bar
EP 1 : 0.18 Bar
EP 2 : 0.15 Bar
Measured in 4th gear at full boost near redline.
wow great info on restrictiveness of different setups...might you have some number for some of the other systems out there, there are so so many exhaust systems to choose from on these cars, making the right choice can be hard sometimes! thank you for your time and consideration
Old Feb 9, 2011 | 04:25 PM
  #32
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Believe this or not Marski system I have in my car has no drone...
Robert
Old Feb 9, 2011 | 06:06 PM
  #33
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Originally Posted by Zeroh
My Milltek 200 on my X50 did drone slightly at around 2500-3000rpm... not annoyingly, but certainly noticeably - however, since I added Ruf Manifolds, the drone has gone. Must be something to do with the changed flow characteristics, but zero drone now & am very happy.
My Milltek is still in the box, and I'm planning on installing it before the snow is gone.
Are you talking about Ruf headers?
Old Feb 9, 2011 | 07:26 PM
  #34
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Ruf : 0.22 Bar
EP 1 : 0.18 Bar
EP 2 : 0.15 Bar
I'll trade a little backpressure for no drone all day.
Old Feb 9, 2011 | 09:54 PM
  #35
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Me too
Old Feb 9, 2011 | 10:12 PM
  #36
pwdrhound's Avatar
Originally Posted by gearhead
Me too
Me three
Old Feb 9, 2011 | 10:14 PM
  #37
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
That milltek above looks to be built pretty well.
I might pick one up to replace the Fabspeed I have on currently.
Old Feb 9, 2011 | 11:12 PM
  #38
porschenaround's Avatar
porschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of light
Has anyone pick'ed up some rattles since changing exhaust and flywheel? i get an occasional 1500 to 2500 rpm rattle that noone can isolate. its intermittent. at just the right frequency and duration. sounds like a loose heat shield. ruf550. i had it even with other exhausts i used in past.
Old Feb 9, 2011 | 11:13 PM
  #39
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
I have a few of those I cant find in some exhaust frequencies.
Old Feb 10, 2011 | 12:05 AM
  #40
reddswiss's Avatar
reddswiss has a spectacular aura aboutreddswiss has a spectacular aura about
How is the cargraphics for drone? thinking of having a used set sent from the states unless anyone knows of a used set in Europe, CH. Is there a forum for used parts for 996tt in Europe? I need to increase my posts before I can post WTB.
Old Feb 10, 2011 | 12:16 AM
  #41
gearhead's Avatar
I had an exhaust heat shield rattle on my old bmw z3 I had years ago as well on a lexus rx300. Annoying, but if its the case its a easy fix.
But if you had it with other exhausts in the same car you got something else on your hands. I know when I had a 3 inch exhaust (loud as hell, hated it) I would get lots of vibration at certain rpm from the bass like vibration you get from subwoofers which was causing rattles in my door panels.
Old Feb 10, 2011 | 06:16 AM
  #42
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Gearhead,
You should look at the Designtek system as I believe it is produced parallel to the Milltek system (just labeled differently) at a fraction of the cost (approx. USD 2300)
http://designtek.eu/design-tek/products/designtek-porsche-turbo-sports-ss-exhaust/
The Milltek system is just perfect with no drone and a perfect exhaust note in my ears.
Cheers,
JE
Old Feb 10, 2011 | 07:49 AM
  #43
johnspeed's Avatar
HI Reddswiss,Cargrahics has no drone.European car magazine did a test on it,sept 2007,it made excellent HP/TQ improvements on a X-50,plus great sound.Thats why I bought mine.I have mine for sale now in parts on this site,but not for long.The ad tells all.......Good Luck
Old Feb 10, 2011 | 09:59 AM
  #44
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
Go to e b a y Germany, lots of used exhausts over there.
Old Feb 10, 2011 | 10:31 AM
  #45
Here is some more info :
The stock exhaust uses 300 cell cats. The 100 cell "sport" cats are less restrictive so the backpressure with these is lower and lower backpressure is what you want.
Reducing backpressure benefits turbine efficiency which results in better boost response and more boost.
If you go from 300 cell to 100 cell then you need to increase the volume of the cat so that the total contact area remains the same. That is the only way to avoid a CEL problem.
Also a big diameter / short 100 cell cat is less restrictive than a small diameter / long 100 cell cat even when their total contact area / volume is identical.
The 200 cell cats are less restrictive than the stock 300 cell cats but more restrictive than the 100 cell cats.
Cheers, Stef
