Wrapping up winter projects - GT2 slave mod, replace plugs, install Speedtech
Old Feb 11, 2011 | 05:49 AM
tbarcelo's Avatar
tbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of light
So I'm finally wrapping up a few weeks at picking away at some winter projects:
  1. GT2 Slave mod
  2. Replace plugs
  3. Install Speedtech 2.5" cross-flow exhaust
Special thanks to gearhead, Scottslaw, and John at Speedtech for their support.
Last night I got the exhaust (minus tips) installed - all I've got left is to put the bumper on and make sure I didn't screw anything up.
Re GT2 mod - for anyone interested I took gearhead's fantastic post on the topic and merged his information plus the threads he mentions plus the EVOMS instructions plus any comments/advice/suggestions people had into this document:
https://docs.google.com/document/d/1...thkey=CJzqyOED
Just to be clear - I take no credit for the content. I just reorganized it a bit to make it easier to follow as a set of instructions.
In summary, none of the projects went super-smooth with the exception of the plug install (super easy once you have everything apart). On the GT2 mod, I struggled to remove and reinstall the PS pump. It is very doable, but there is just not much clearance to get that thing in and out of there. I have no idea how you would do it with the reservoir attached.
The OEM slave uninstall went fairly smoothly - it is awkward work and some of the lines are difficult to remove, but not that bad. The hardest part of GT2 slave install was getting the slave bracket bolts to start threading. I had no problem getting everything roughly into position, but getting the alignment done and the bolts started was tricky.
While doing the master swap I snapped a hydraulic line going into the OEM master while removing it. Luckily it was a cheap part and easy to replace - other than the pain of working on your back under the dashboard, the master cylinder stuff is pretty easy.
Re exhaust install - minor issues. Mainly, I had trouble aligning the Speedtech v-flanges. I ended up having to unbolt the cats from the turbos slightly to get a little more play in everything. After that, it all managed to bolt up fine.
I am more than happy to share my experiences with anyone, but frankly, I learned how to do all of this stuff with support from the forum (particularly the members mentioned above). I'm no crack mechanic, but as frustrating as certain moments were, I'm satisfied with knowing I did it all (ask me that again when I actually fire the thing up and find steering fluid leaking and exhaust gas escaping
-Trevor
Old Feb 11, 2011 | 06:10 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
enjoy new mods after they are done
Old Feb 11, 2011 | 06:11 AM
tbarcelo's Avatar
Thanks - I'm looking forward to it. Unfortunately, during the winter my 911 lives in a side garage bay - access to that bay is currently covered in > 3 ft of snow. Before too long I may need to use the snow blower to at least thin out the snow pack so I can drive the car before July!
Old Feb 11, 2011 | 08:34 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
What clutch are you running? still stock?
Old Feb 11, 2011 | 08:49 AM
tbarcelo's Avatar
Yeah, still stock. Other than the GT2 slave and new exhaust the car is unmodded. I'll probably get an EPL flash at some point, but I don't think I'm going to do anything else. Frankly, I'm tired of wrenching on it, so I'll probably hold off on the EPL flash, too, so the stock clutch lasts a little longer
Old Feb 11, 2011 | 09:49 AM
XLR82XS's Avatar
Don't wait for the flash. You'll wonder how you drove without it.
Old Feb 11, 2011 | 01:02 PM
John@SpeedTech's Avatar
Hi Trevor,
That's great! Half the fun of owning these cars is doing a little work on them from time to time and getting to know how they are put together and work, etc. - it can be very rewarding and satisfying.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Feb 11, 2011 | 02:37 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Nice! We should get together at a car show or something once the weather turns around. I want to hear that exhaust
Old Feb 11, 2011 | 04:29 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Nicely done, glad I could help. It makes it way better. Give me a update when you get it on the road.
Old Feb 11, 2011 | 06:29 PM
tbarcelo's Avatar
Woo-hoo, it starts. I decided to try to get some heat in the new exhaust system before putting the rear bumper back on.
ETW - no problem. Come April let's find a time / place.
Thanks again Scott & John.
awdbiturbo1
Feb 18, 2016 10:24 AM
SharkyShark20
Sep 19, 2015 09:54 PM
no1joey
Sep 2, 2015 12:32 AM
TrackOne
Aug 20, 2015 12:56 PM
