A little FYI about spark plugs....
Old Feb 15, 2011 | 01:31 AM
ThePunisher's Avatar
ThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud of
And what about DENSO PK20PR-P8 Double Platinum ... it looked to be a common choice for high hp application (above 600-650 hp)?
Old Feb 15, 2011 | 08:34 AM
XLR82XS's Avatar
Copper is the best especially in high hp/boosted applications.
Old Feb 15, 2011 | 10:07 AM
raineycd's Avatar
That's what I am running per Markski's recommendation. They have been very good so far!
Old Feb 15, 2011 | 10:54 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Just to clarify guys,
are we saying the plugs can be changed without removing both the rear bumper and IC's.
Did mine in May last but had to change the Turbos as well because of corrosion issues. I did wonder what I would do next time it was time for a plug or coil pack change.
Cheers,
Frank
Old Feb 15, 2011 | 11:07 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
I didn't remove the bumper.
Old Feb 15, 2011 | 11:29 AM
johnspeed's Avatar
Hi Guys,,,,,,,So the Bosch FR6LDC is not the favored spark plug anymore??I was even thinking about trying the next colder one down ,5, in that series...I have had great luck with that plug and they are still going strong after 15,000 miles on them.....
Old Feb 15, 2011 | 11:56 AM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Originally Posted by vntperformance
No one runs iridium plugs? I run NGK Iridiuims in my supra and heck they last a long time!
I run the NGK Iridiums (as a previous Supra guy myself) and they work like a charm. IIRC, someone here installed some Denso IK-22s, didn't check the factory gap (which is way too big for the 996), and had misfire issues -thus iridium plugs got some bad press around here.
Old Feb 15, 2011 | 12:46 PM
raineycd's Avatar
lol that was me, but they shouldn't use a generic part number for our car if the gap is wrong, IMO...
raineycd's Avatar
I call BS! Please explain kind sir!
Old Feb 15, 2011 | 12:51 PM
earl3's Avatar
ahh I knew it was someone familiar Thats a good point on them listing a part number for the car that doesn't exactly work. Gapping iridiums is not the easiest thing either. The NGK version of the iridium plug (vice Denso) comes with a gap that is more appropriate for our cars.
Old Feb 15, 2011 | 01:29 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
I would love to hear how to change the sparkplugs without removing the rear bumper and intercoolers.
Old Feb 15, 2011 | 01:39 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Improper gap, & blame the type of plugs...wtf?
Old Feb 15, 2011 | 01:40 PM
k-ore's Avatar
Incorrect...copper will foul out faster at high boost then a iridium plug, granted that both plugs are gapped properly.
Old Feb 15, 2011 | 02:44 PM
XLR82XS's Avatar
I ran NGK 3330s in my first Supra and run coppers in my current white 1000hp Supra. Nothing else worked without hesitating, popping, etc... The 996TT may be a different story. Mine currently has whatever the PO had installed at the dealer 2K miles ago so I'm assuming its a OE plug.
Old Feb 15, 2011 | 03:07 PM
as4driver's Avatar
as4driver is infamous around these parts
I always use coppers ngk bkr7e.
Evan
