HELP stranded
Old Feb 20, 2017 | 01:48 PM
  #31
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Originally Posted by boyg
Work shop took a look on the throttle and tried to move it, it found it is kind of a bit jammed but it is ok after manually move the flip, the car now performs ok again, and the throttle was actually v clean at all. Thats made me quite worry it will be happen again in soon future actually...
That doesn't sound like they solved anything. If it happens again, look for air leaks. Actually, if you haven't done it yet, you should do a boost leak test anyways.
Old Feb 20, 2017 | 01:50 PM
  #32
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Boost leaks have nothing to do with those codes. It's a throttle issue.
Old Feb 20, 2017 | 03:06 PM
  #33
Not sure if you missed my post earlier. These were the codes that I had before I found a vacuum leak on my intake. I had no issues with my throttle at all. I know your issue was related to throttle but it's not always the case with these codes. Hopefully the op doesn't have any more problems but if he does, he should leak test.
ID:	470122   Click image for larger version
Old Feb 20, 2017 | 07:33 PM
  #34
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Below is the read out from durametric, both at idle, the left hand side was pretty abnormal, and the right hand side was last night when it was fine and I drove it home, but still, I am still worrying it will come back again, I will be joining Track day after couple weeks...
Old Feb 20, 2017 | 08:06 PM
  #35
996tt550hp's Avatar
Clean your throttle plate off. I got half of those codes. Spring test fail if that happens you can't drive the car. You can't touch the throttle without removing the electrical connector if you do touch it you will damage it if you don't disconnect it.
Again to you it looks clean but the other side is not.
Old Feb 20, 2017 | 08:20 PM
  #36
boyg's Avatar
Right, btw, the workshop found the throttle wasnt hold tight as it should be, sounds like it could be electronic\throttle issue.
Old Feb 20, 2017 | 08:53 PM
  #37
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
this would lead me to think the TB gear is worn or broken and will probably come back .
Old Feb 20, 2017 | 10:59 PM
  #38
boyg's Avatar
I do have the same thought, grabbed a 987 used one from Ebay to be replace...
Old Feb 21, 2017 | 04:55 AM
  #39
996tt550hp's Avatar
It's not worn it's dirty. The chances of you breaking the TB is very very slim. Clean the front and back plate. Throttle cleaner
Old Feb 21, 2017 | 04:59 AM
  #40
boyg's Avatar
Got it, buying a spare one bcos of I am going to track at the beginning of March, I cant let it down and play safe.
Old Feb 21, 2017 | 05:01 AM
  #41
996tt550hp's Avatar
Got it. Awesome
Follow these steps
Take the black connector off in front of the throttle.
Then spray it with throttle cleaner and wipe it with a towel front and rear.
Re connect the plug.
Turn the key in the on position for 1 min. Dont Start your car!
Turn off for 10 seconds.
Then start your car.
Old Feb 21, 2017 | 05:18 AM
  #42
boyg's Avatar
Got it. Awesome
Follow these steps
Appreciated.
As per you say, you should create a thread of DIY throttle cleaning
Old Feb 21, 2017 | 08:21 AM
  #43
996tt550hp's Avatar
Appreciated.
Good point. I should it really sucks this happened to you. When I had these codes 32krazy said it was my throttle body messed up.
Old Feb 21, 2017 | 12:01 PM
  #44
joetwint's Avatar
Throttle jacking is a good sign that your throttle plate is dirty. Even if it doesn't look dirty the sensor where your position sensor is needs to Cleve cleaned because of the oil in the boost hoses..
Which sensor are u cleaning? Can u shos me what u are referring to?
cordsig79
Cayenne 955/957
Aug 28, 2015 12:36 PM
DSCOFF
Aug 23, 2015 01:22 PM
KPV
Jul 17, 2004 06:59 AM
